"Official" Olive Thread Opus 4, Opus 6, Melody 2, Olive 2, Olive 4/ 4HD, 06HD - Page 104 - AVS Forum
 4Likes
post #3091 of 3104 Old 10-08-2014, 08:17 PM
mkjelsbe's Avatar
Marc,
I don't doubt that transferring files to the OliveOne will be no worse than any other device such as Sonos, or whatever, I just wish that the bizarre encryption code in our old Olive devices was breakable so that our editing in the old device could be transferred over automatically. I'm not even talking about the extra/esoteric fields that I put in like "orchestra" or "chorus", but simply wish that the basic artist/album/track name would come over as I had edited them.
Mike
mkjelsbe is offline
post #3092 of 3104 Old 10-09-2014, 06:44 AM
mumsoft's Avatar
Quoted: 14 Post(s)
Originally Posted by mkjelsbe View Post
Marc,
Mike
Hi Mike,
There is no such thing as an encryption code in your Olive. It's just its habit of keeping ALL your valuable edits in the unencrypted, not-password protected, plain vanilla SQLite database zDB, and nothing of it goes to the track-files. These are kept unaltered from day 1. Only if you had edited them on your pc and had imported them in your Olive, they would contain just what you entered when exported to XBMC or whatever. But nothing that you changed after the import.
I guess, but it's just a guess, that Olive will provide a tool to transfer files form your 'old' Olive to the new one. Having that said, for my bunch of Olives 4 I only can rely on the horrible backup and restore 'tool', nothing fancy of that sort.
Marc
mumsoft is offline
post #3093 of 3104 Old 10-11-2014, 05:09 PM
Liked: 0
Has anyone had the Opus 4 and the 06HD. I just wondering if there is any sound difference between the two.
olive hd is offline
post #3094 of 3104 Old 10-12-2014, 12:49 AM
mumsoft's Avatar
Quoted: 14 Post(s)
Of course there is. It's obvious when playing 24 bit material. :-)
mumsoft is offline
post #3095 of 3104 Old 10-12-2014, 11:24 PM
Liked: 0
If you were reffering to my post. How many bit is the Opus 4
olive hd is offline
post #3096 of 3104 Old 10-13-2014, 12:13 AM
mumsoft's Avatar
Quoted: 14 Post(s)
16 bit and max 96Khz resolution. Yielding to 96dB for the loudest and 48Kh for the highest tone.
But that is just theory. There is much more that influences the sound.
Maybe Mark Rubin can address that.
Anyway, I bought 3 Olive 4's because the sound is beatiful enough for me.
mumsoft is offline
post #3097 of 3104 Old 10-14-2014, 11:27 AM
clpetersen's Avatar
Quoted: 35 Post(s)
Liked: 25
Me too. So we will cry stereophonically... :-)
I think that transfering the music to an Olive1 will not be such a disaster, but... you never know. In stead, take a Sonos or so, what then?
As the old saying goes, it takes two to tango.
The Sonos or so will have to eat what the Olive spits out.
So you need a decent import function, but the so-so streamer needs to have the same fields in its database. Roughly. That is the real challenge.
Marc
Yup. I shed my tears early. Been using JRiver, now version 20, which rips on a Mac and gets the metadata usually correct except of course for classical. However, JRiver has a very deep tag set (conductor, orchestra, chorus, etc.), and writes everything into the file metadata (as compared to Olive which keeps in the Olive SQL database).
So, rip using JRiver, XLD or similar, get everything right and then transfer to the Olive. As Marc says, the Olive will spit the files out again, correctly.
Players like Sonos or Bluesound only read in the metadata; they do not create metadata databases (except for a library index).
clpetersen is offline
post #3098 of 3104 Old 10-14-2014, 01:26 PM
mumsoft's Avatar
Quoted: 14 Post(s)
If there is a way to import data into the other device batch-wise, and if you are able to create an importfile with some neat SQL-statements, theoretically it must be possible to transfer the SQL-metadata to the other-device-metadata.
But it will be a challenge. For most of us, the first challenge is to access the zDB directly.
Marc
mumsoft is offline
post #3099 of 3104 Old 10-15-2014, 05:38 AM
Liked: 0
Why is it when you merge albums they are never in order. I find this really annoying.
olive hd is offline
post #3100 of 3104 Old 10-15-2014, 09:21 AM
td_mn's Avatar
Marc,
Was curious if you ever successfully replaced the display with this one
BTW ever since I updated my fstab with your mod my olive 4 has been free of disk issues Thx!
Tom
td_mn is offline
post #3101 of 3104 Old 10-15-2014, 09:42 PM
Liked: 0
I purchased a new router Netgear and now i cant access Maestro. Any idea on how i can access it?
The error is 400 bad request.
olive hd is offline
post #3102 of 3104 Old 10-16-2014, 09:24 PM
Liked: 0
If anyone has Netgear AC 1600. I really need your help.
I cant access the Maestro interface with this new router.
olive hd is offline
post #3103 of 3104 Old Yesterday, 02:44 AM
Liked: 0
Same Netgear, same problem. neither wired nor wifi connect
surtep is offline
post #3104 of 3104 Old Yesterday, 04:51 PM
mraudioguru's Avatar
I just upgraded my router with a new dual band model. It changed all of my IP addresses on all of devices. You guys will need to get into the Olive's system info and see what the new IP address is and change it in Maestro so that it will work.
mraudioguru is offline
Reply CD Players & Dedicated Music Transports
User Tag List
