"Official" Olive Thread Opus 4, Opus 6, Melody 2, Olive 2, Olive 4/ 4HD, 06HD - Page 111 - AVS | Home Theater Discussions And Reviews
 32Likes
post #3301 of 3321 Old 03-19-2015, 01:28 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
An Olive is a Linux pc. It uses a hard disk intensively to do its thing.
My Olives have shown too many times the ever lasting boot-up screen, and there always was some nasty file in the 5th partition that caused the peril.
Then repairing this partition with fsck was enough to let the music flow.
Of course there can be numerous causes for this behaviour, but a recovery would be my last resort.
Since my Olives do the check proactively at every boot, they behave much more reliable.
It takes some guts, opening the unit, getting hold on something of a Linux pc (knoppix comes to mind) or at least a way to do the check, but it is worth the effort.
Marc
mumsoft is offline
post #3302 of 3321 Old 03-19-2015, 04:56 AM
GJ1970's Avatar
I was able to get my hands on a second hand Olive2 and Olive 3HD.
I want to change the harddisk, but I don' really see how to remove the cover. The screws on the side and one on the bottom are removed, but cover and bottom are still stuck. Did anyone succeed in this or knows how to remove the top?
Btw, when we talk about the 4HD on this forum, do we mean the old 4HD or the new 4HD? (Thank you Olive for naming 2 different products the same name within 2-3 years)
Thanks in advance!
Gertjan
GJ1970 is online now
post #3303 of 3321 Old 03-19-2015, 05:37 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
Thanks in advance!
Gertjan
I have seen how a friend of me opened his O3HD. It was not as easy as it is for an Olive4. As I recall correctly, you have also to loose the screws of the powercord-entry (my English is velly bad) . If you like, I'll ask him to describe it in Dutch. But try first.
Marc
mumsoft is offline
post #3304 of 3321 Old 03-19-2015, 08:23 AM
GJ1970's Avatar
Marc
With a lot of carefull force, I was able to lift the cover a bit. With that, There is little acces but enough to disconnect the power connector. On the front there are 2 delicate ribbons to the LCD screen and buttons. The olive 4 connections where more robust, although it was taped..
Since I was used to the 4, the recovery is new to me. I forgot to download the ODBInstall part. So thanks very much for the just created manual! The problem was found very easy, including the link, which is missing on the olive.us site.
If the install works, I will open the complete unit (I just switched the wires on the harddisk) and make some pictures, including the info to open up the unit.
post #3305 of 3321 Old 03-19-2015, 09:11 AM
GJ1970's Avatar
Originally Posted by fateli View Post
Hello guys!
I'm having issues with my Olive O6HD concerning the startup. It shows the white screen of the system starting up and that's it. It doesn't come out of this. I tried the tips included in the instructions but no success
I also tried restoring the Ovile using the methods that the FAQ oriented (trough USB recovery and CD) and the image downloaded on the Olive website is broken and I cannot burn it into the CD.
I managed to get the (please insert the usb stick) screen but it didnt recognized the flash drive. apparently everything is OK but no success...
Is there any other alternative to resolve this issue?
Cheers!
Both files should be on the usb stick. I forgot one on the usb stick and nothing happened. Also do not forget to to format the usb stick to FAT32 with 4096 bytes default clustering.
Good Luck!
post #3306 of 3321 Old 03-19-2015, 01:50 PM
Liked: 0
Olive 04HD is not working
Hi Experts,
I've done pretty much everything I could and still no clue why is not working.
My 04HD hangs on Starting up.
I've tried USB recovery but after I insert USB stick nothing happens. I did all as mentioned in your guide. Finally I tried CD recovery and it started and after 10 second says that Hard Disk recovery failed. I've checked the hard drive by connection to PC (win). It was recognized correctly so I've deleted partitions but it didn't help. I've replaced with new hard drive but it didn't help either. Olive support is not answering my emails.
Questions:
1.) Why do you think USB is not working
2.) Is it possible to connect my 04HD to some video (monitor) and check how is booting?
I'll be appreciated for any help.
Cheers,
sebastian
sebas--q is offline
post #3307 of 3321 Old 03-19-2015, 02:36 PM
GJ1970's Avatar
That was rather painless :
The Olive 3HD has now a 2 TB harddisk, without too much trouble.
I made some pictures of the inside and put my experience in a document for later use. I wanted to post it here but the limit is 20kb...
I only forgot that the Olive does not import all tags and that the albums are listed on alphabet, instead of year... So I think that ill keep my NAS audio server up and running
post #3308 of 3321 Old 03-19-2015, 06:43 PM
fateli's Avatar
Liked: 0
Hello again.
I followed the exact steps about the recovery process via the USB port with a stick and my Olive don't recognize it at all
the "insert the USB stick now" keeps stil on the screen and the restoring process don't begin.
I tried burning the recovery CD image but in every program it says that the disc image is corrupt and can't read it nor burn.
Is there any other suggestion that might solve my problem:
Cheers
fateli is offline
post #3309 of 3321 Old 03-19-2015, 11:25 PM
GJ1970's Avatar
The "cd image" for the Hd models is not for burning them on cd. Probably a left over from the 4 model. Can you confirm that both files are on the usb stick? The usb stick is FAT32 with 4096 bytes clusters?
post #3310 of 3321 Old 03-20-2015, 05:14 AM
Liked: 0
Yes, right.
I think of making a document about my backup-method. I have described it in this thread, will look it up.
That takes some time though.
Anyway, I make backups so that the backup disk can be mounted in an Olive, and works right away. No tedious restore process.
Marc
Hi Marc,
I ran fsck on my original Olive disk and it found errors on partition 2 and 3, none on partition 5. Then I opened the RCS
file and found a command line that checks partition 5. The question is, are the intermittend pauses while playing music as well
as the freezing of the unit really connected to partition 5 or are 2 or the 3 reason for it, or is there another fault in the unit?
Cheers
Marc H.
hueser is offline
post #3311 of 3321 Old 03-20-2015, 05:53 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
With errors on partition 2 and 3 you never know how your Olive behaves. Having repaired them, if possible, gives you at least a healthy Olive system back. So that may prove to be the whole problem.
Just try.
Marc
mumsoft is offline
post #3312 of 3321 Old 03-20-2015, 06:05 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
If you found the fsck on sda5 in rCS, you problably have changed in on my advice.
After booting and a proper turning off, there will always be an error left in sda5. So, a properly working Olive creates an error... ;-(
Marc
mumsoft is offline
post #3313 of 3321 Old 03-20-2015, 06:27 AM
Liked: 0
Marc
Hi Marc,
no, I was about to add the line you proposed but then I found a section coming after the sda7 check beginning with the comment
# edited by Colin
...fsck /dev/sda5
Have you added the fsck for part2 and 3 into the rcs file?
Cheers
Marc H.
hueser is offline
post #3314 of 3321 Old 03-20-2015, 07:10 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
Oh well, then I think Olive changed it on my advice. ;-)
There is no way to fsck the system partition. That is, without altering the boot-up process completely.
Olive was so wise to move the so called cfg and data partition aside in sda5 and sda7, making the system partition less prone to write errors. But still they can occur as you have experienced.
There is nothing to do about that.
NB there is only one system partitition and it is either sda2 or 3. The other is a previous system partition with the previous Olive version. It is not used.
Marc
mumsoft is offline
post #3315 of 3321 Old 03-27-2015, 08:27 PM
wbk
wbk's Avatar
Quoted: 21 Post(s)
The HDD that Marc has seems to have decent enough specifications, to get it working in an Olive.
Other Marc
Marc, I disagree. The olive is an audio component using a hard drive and requires a specialized hard drive-the Western Digital wd20EURS which a western digital support person indicated was designed for "audio components." Another hard drive "having decent enough specifications" may not work.
wbk is offline
post #3316 of 3321 Old 03-28-2015, 03:45 AM
mumsoft's Avatar
Quoted: 40 Post(s)
Liked: 25
We don't have to quarrel about this. When I searched for a replacement I looked at the noise and the drawn current. Speed is no issue. If both parameters are less than what the original drive delivers, it can be a suitable drive. It can work in an Olive.
Maybe an 'audio' HDD is better suited or works longer, but both drives can work.
Marc
mumsoft is offline
post #3317 of 3321 Old Yesterday, 03:59 PM
clpetersen's Avatar
Quoted: 76 Post(s)
Liked: 30
Marc
I agree with Marc's advice. I have replaced three hard drives in Olives - two in my own and one for another member. None were due to failures, but to get better performance - usually audible noise. In all cases we found drives that were both quieter and used less power than the original. Not surprising as drives continue to improve. Used 5400 rpm to get best audible noise; data rates far exceed anything needed for audio. Always replaced with a drive of equal or smaller size to avoid potential conflicts.
mumsoft and GJ1970 like this.
clpetersen is online now
post #3318 of 3321 Old Today, 06:49 AM
GJ1970's Avatar
With ext2fsd from http://www.ext2fsd.com/, a linux based drive can be connected to a windows machine. Via this program you can access the harddrive of the olive or the backup drive.
I created a program in windows that decrypts the database from the backup drive and with the data in the database, copies the tracks to \ARTIST\ALBUM\TRACKNR - TRACKTITLE. it also copies the folder images to that location. There is no tag editing, but that can be done via other programs e.g. Mp3tag
Before I make this program available (don't know yet where..), I would like somebody else to take a look at it. Anybody interested?
Best regards, Gertjan
clpetersen likes this.
post #3319 of 3321 Old Today, 06:55 AM
GJ1970's Avatar
B.t.w., After I found out how to decrypt the database, I found out, someone had done that already: https://github.com/dogshoes/zcryp
post #3320 of 3321 Unread Today, 08:40 AM
clpetersen's Avatar
Quoted: 76 Post(s)
Liked: 30
I will definitely try this. Is this for backups created after software version 4.20? There was a big change - back-ups were no longer in '.tar' format.
post #3321 of 3321 Unread Today, 09:17 AM
GJ1970's Avatar
I have tested this with a backup, created with version 4.3.2
I will PM you later with the details of the program and where to upload..
Reply CD Players & Dedicated Music Transports
