"Official" Olive Thread Opus 4, Opus 6, Melody 2, Olive 2, Olive 4/ 4HD, 06HD - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #3571 of 3588 Old 12-04-2015, 06:36 AM
mumsoft's Avatar
Quoted: 98 Post(s)
Liked: 35
nothing more isn't much. It should end with a recovery successful message and reboot.
Whit my Olive 4 came a recovery cd that does just that. I downloaded a newer version and that one says always after several minutes that the recovery has failed. Another one wirh the same version fails immediately, and does nothing at all.
Marc
mumsoft is offline
post #3572 of 3588 Old 12-04-2015, 06:49 AM
GJ1970's Avatar
Originally Posted by PArmola View Post
Yes my original HD does boot and works flawlessly. The recovery does not fail as it just continues with the startup screen and nothing more.
Be aware that the first startup after a recovery can take a couple of hours! My Olive 3 showed the startup screen for 2,5 hours before it was started correctly. To be sure, I suggest that you try to recover in the night and check again in the morning
Succes!
Gertjan
GJ1970 is online now
post #3573 of 3588 Old 12-05-2015, 10:43 AM
wbk
wbk's Avatar
Quoted: 29 Post(s)
Originally Posted by mumsoft View Post
How should I know? I read positive, negative and neutral reviews, I decide to buy and try. That's it.
Some-one with insight thought it does away with EMT. Maybe.
Marc
Marc, You misunderstood my question. You are obviously listening to music through your O4 in order to note the "finer highs" etc caused by the jitterbug. My question is how do you listen to your music through the jitterbug when the jitterbug is connected to the USB port which is only for backup and restore.
Stated differently, you are very probably listening to music coming from either the analog outs of your Olive or the digital out (when you get the DAC). Neither involve the USB port to which the jitterbug is connected. So how does the jitterbug connected to the usb port affect the sound from the analog outs or the digital out.
wbk is offline
post #3574 of 3588 Old 12-05-2015, 02:16 PM
mumsoft's Avatar
Quoted: 98 Post(s)
Liked: 35
In the manual of the jitterbug there is an example that uses a jitterbug in an unused USB-port. That's indeed the way I have applied the jitterbug. Then you ask me how it can be that it influences the music. My answer is: I really don't know. Someone suggested it reduces the electro magnetic smog (EMS).
It's not my cup of tea, all these audio related technical stuff, I listen, I can hear differences (to a certain extend), and that's enough for me.
Marc
mumsoft is offline
post #3575 of 3588 Old 12-09-2015, 10:12 AM
wbk
wbk's Avatar
Quoted: 29 Post(s)
Marc
Marc, I didn't realize you inserted the jitterbug in a unused port. Interested that it improves the sound
wbk is offline
post #3576 of 3588 Old 12-09-2015, 03:05 PM
wbk
wbk's Avatar
Quoted: 29 Post(s)
To those of you out there who are following this thread, I am looking for a motherboard for my 06. I will pay a reasonable price.
wbk is offline
post #3577 of 3588 Old 12-10-2015, 04:43 PM
wbk
wbk's Avatar
Quoted: 29 Post(s)
Marc, I decide to order a jitterbug and will place it at the USB port of my olive and then backup from the USB port to an external USB drive according to the olive manual ( the "midevel" way ); then reverse the process by "restoring" from the external hard drive back through the jitterbug to the olive. Should be interesting.
wbk is offline
post #3578 of 3588 Old 12-10-2015, 05:01 PM
mumsoft's Avatar
Quoted: 98 Post(s)
Liked: 35
If that doesn't work just remove it. The purpose is that it improves the sound, but I have read reviews that critisize the normal USB functionallity.
mumsoft is offline
post #3579 of 3588 Old 12-11-2015, 12:26 PM
mumsoft's Avatar
Quoted: 98 Post(s)
Liked: 35
In my set in works flawlessly.
Marc
mumsoft is offline
post #3580 of 3588 Old 01-08-2016, 03:34 AM
andyjh's Avatar
Hopefully someone can help me with this,
as my 04HD is starting to do odd things, I checked the software and firmware versions and got this
Software 4.3.2
Firmware 0.0
as I have read about a Firmware V3, mine at 0.0 doesn't seem right
is this right?
thanks - Andy
andyjh is offline
post #3581 of 3588 Old 01-12-2016, 06:19 PM
Liked: 0
Hello,
I wonder if any of you guys might be able to help me?
I've been using an Olive Opus 4 for a few years with no problems at all, recently I moved it in a reorganisation and it has started being unpredictable.
Sometimes it won't progress beyond the start-up screen, sometimes I can get as far as getting into my library but it always get to a point after a short while where the loading symbol comes up and less and less functions work until it completely freezes up and I have to power down and try again.
I'm not really technical on the computing side of things and didn't have the Olive from new so don't have a recovery disc, are there any simple reset options which are likely to get my Opus up and running again?
Thanks for any suggestions
Ng199 is offline
post #3582 of 3588 Old 01-13-2016, 03:07 AM
mumsoft's Avatar
Quoted: 98 Post(s)
Liked: 35
You can find a recovery cd (image) here: http://www.olive.us/support/software/reinstall.html
Using that will demand that you have a proper backup of your music, else this recovery behaves as a disaster!
Most likely your Olive system partition has some errors, and if I were you, I would try to repair that, before doing a recovery, which is so time consuming and prone to error. But if you're not technical, try to find someone in your neighbourhood with some Linux skills, to check the disk. Opening an Olive 4 isn't difficult, but it takes some special screwdriver.
Marc
mumsoft is offline
post #3583 of 3588 Old 01-14-2016, 02:07 AM
Liked: 1
Software 4.3.2
Firmware 0.0
is this right?
thanks - Andy
Hi,
I have experienced the same situation, i.e. my Olive with the software and firmware versions you are mentioning started doing odd things, in my case the display was freezing very soon after startup. Unfortunately I am not sure what the firmware does, presumably it adjusts some electrical values to compensate for aging effects. I changed to Version 3 and now my Olive is running fine. Nevertheless there seems to be a risk in updating the firmware as I have written in one of my messages. It is up to you whether you want to update to firmware version 3 or not. It depends on the pain you have, I guess. My Olive was basically non-functional, because the freezing of the display was accompanied by sound dropouts.
Cheers
Marc H.
hueser is offline
post #3584 of 3588 Old 01-29-2016, 04:38 PM
Bram Hillen's Avatar
Touchscreen 4 HD is broken. I am living in the Netherlands, and till now I didn,t succeed in getting a replacememt for the broken touchscreen. ( Audiac the distributor does NOT give ANY support anymore ). I do hope there is a spare part available.Sevond hand is ok. Right now I am not able to do anything with the unit, while containing some 2560 WAV albums....
Bram Hillen is offline
post #3585 of 3588 Old 01-31-2016, 04:13 PM
Liked: 0
Hello, dear fellow Olive 'fans'
A few days ago, my so far relatively reliable Olive 4HD went into a funny state: when booting up, the displays shows the white “System starting up, please wait” welcome screen, then flickers and starts flashing alternating an empty black screen with the white welcome screen – and never comes out of this loop. I cannot get access to the 4HD from my computer or my iPad either.
I tried all the recommendations in wbk’s very helpful “OLIVE TROUBLESHOOTING GUIDE 2.0” (post #3229 ) but no joy. Given that I have backed up the 4HD recently, I eventually decided to try a recovery. I downloaded the required files, prepared the USB as per the instructions, turned on the 4HD, pushed the center and down buttons and… nothing – no prompt, no signs of any activity (except for the sound of the hard drive spinning) – just the ‘frozen’ white screen.
As suggested by wbk in step V.E., I have tried to turn the Olive off, insert the stick and turn the Olive on, both with and without the center and down buttons pressed - again, without any visible response.
I contacted Olive by e-mail and they said it is probably a motherboard failure, but I suspect a software failure is more likely.
Does any of you have any suggestions as to how to kick the 4HD into recovery mode without using the front panel buttons? Or any other ideas?
Thanks in advance for any assistance.
Miguel
mruano is offline
post #3586 of 3588 Old 02-02-2016, 08:56 AM
Liked: 0
Marvell CPU used in Olive 06hd
I am trying to locate information regarding the Marvell chip used in the Olive 06hd board. Does anyone know if the Marvell CPU is an ARM based chip or an Intell x86 chipset? Or neither?
presentmontra is offline
post #3587 of 3588 Old Yesterday, 06:33 PM
andyjh's Avatar
Can anyone let me know where I can get Firmware V3 for my Olive 04HD,
I have seen many people here say they have loaded it in, but I cannot find this download anywhere.
Buying the Olive 04HD is the biggest mistake I have ever made, so I am about to buy a Cocktail Audio X40, but I thought I would give the 04HD one last chance to be recovered from the non functioning state it has got into, as I do have over 16000 tracks loaded into it, and I don't fancy starting again with another music server.
thanks - Andy
andyjh is offline
post #3588 of 3588 Old Today, 12:48 AM
GJ1970's Avatar
Firmware upgrade
For firmware upgrade see the information in this link: http://www.audioaficionado.org/cd-pl...-0-update.html
Success,
Gertjan
Reply CD Players & Dedicated Music Transports
