"Official" Olive Thread Opus 4, Opus 6, Melody 2, Olive 2, Olive 4/ 4HD, 06HD - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 61Likes
post #3691 of 3701 Old 09-13-2016, 11:24 PM
Liked: 0
Originally Posted by mumsoft View Post
Oh no. It's just a matter to tell your Olive that olive.us is online and that it's address is where your Olive is. 127.0.0.1 if I'm correct.
You add this to your hosts file and you're done.
When I am at my pc I will recite the complete file.
Marc
So where do you put this host file? I just found out that my internet radio isn't working.
olive hd is offline
post #3692 of 3701 Old 09-14-2016, 12:10 AM
Liked: 0
Originally Posted by clpetersen View Post
You are correct.The Oliver server is no longer on-line. There are software work-arounds for this on this forum; not sure about the Melody solution however.
Do you have a link for this. Thanks
olive hd is offline
post #3693 of 3701 Old 09-14-2016, 06:56 AM
mumsoft's Avatar
Quoted: 111 Post(s)
Liked: 36
mumsoft is offline
post #3694 of 3701 Old 09-15-2016, 12:19 AM
Liked: 0
Not sure what code i have to put in and how i get the host file into the Olive.
olive hd is offline
post #3695 of 3701 Old 09-15-2016, 05:15 AM
mumsoft's Avatar
Quoted: 111 Post(s)
Liked: 36
The Lydo site has it all documented.
Take a look here: http://www.lydo.nl/olive/ssh-to-olive/
That will get you inside the Olive. There you have to edit the rcS file as noted in http://www.lydo.nl/olive/internet-down/
Marc
mumsoft is offline
post #3696 of 3701 Old 09-15-2016, 11:21 PM
Liked: 0
Marc
I downloaded WINSCP. what do i use for file protocol, also host name, and port number
Name:	2016-09-16 16_22_08-Login.jpg
olive hd is offline
post #3697 of 3701 Old 09-16-2016, 12:44 AM
mumsoft's Avatar
Quoted: 111 Post(s)
Liked: 36
Protocol is SSH
Anyone else here with Windows who likes to help mr olive hd? For me it's more guessing.
Marc
mumsoft is offline
post #3698 of 3701 Old 09-18-2016, 04:40 PM
Liked: 0
Protocol is SSH
Marc
Hi Marc, can i do this your way by a live Linux CD or does it have to be installed. I can then download the SSH. As there doesn't seem to be anyone who can help me with the Windows version.
Also Olive out of business?
olive hd is offline
post #3699 of 3701 Old Yesterday, 01:30 AM
mumsoft's Avatar
Quoted: 111 Post(s)
Liked: 36
With a live Linux version it will be possible, but I would not recommend you to go this bumpy way.
If Winscp is too difficult, you could try an alternative. Look here for instance:
http://www.htpcbeginner.com/best-ssh...-alternatives/
With the ip-address of your Olive, the username and password, one of these alternatives must be viable.
Good luck
Marc
mumsoft is offline
post #3700 of 3701 Old Yesterday, 01:45 AM
mumsoft's Avatar
Quoted: 111 Post(s)
Liked: 36
Maybe this will also help you with Winscp: http://www.lydo.nl/olive/improved-li...rs-conductors/
Marc
mumsoft is offline
post #3701 of 3701 Old Yesterday, 06:36 AM
GJ1970's Avatar
Quoted: 23 Post(s)
Marc
Back after a while, the last link Marc provided shows the settings for winscp.
Note that the olive 2 melody is write protected, so this fix cannot be applied to the melody.
Best regards,
Gertjan
GJ1970 is offline
Reply CD Players & Dedicated Music Transports
