music - typical CD player vs. typcial DVD ?? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 423 Old 04-07-2009, 08:59 AM
Zues's Avatar
Switching back and fourth is not a blind test. Blind test would be not knowing which input you where on and trying to guess which one is digital or analog.
Yeah, i'm serious when i say on my system analog and digital connection is extremely close.
Zues is offline
post #182 of 423 Old 04-07-2009, 11:29 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
OK, so it had to do with some setting or other affecting one and not the other. Not unusual but easy to overlook especially with the complexity with settings and digging into menus. Even with that Zues, it's quite possible that there not only be absolute levels differences which can range to barely perceptible but there can be L/R skews. Good job. Have a brew on me. Invite some friends.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #183 of 423 Old 04-07-2009, 12:11 PM
Morecambe's Avatar
An interesting original question. Had you asked me a few weeks ago i would have said CDP stand alone no contest. However, a week or so ago I tested my Toshiba HD E1, my Sony BDP - 300 against my old Rotel 965BX (regarded as a classic CDP).
They were all connected to my NAD C370 2CH amp via their respective 2CH outputs. I then put the same CD (I have three copies!) in each player and then matched the song to be a perfect transition when inputs switched on the NAD.
To say I was surprised is an understatement. They were all but indistinguishable from each other. I tried at various sound levels, still the same.
I what people will say, but this is the only way to test. If you switch a disc from one player to the other it is to hard to see a difference. I am not saying there is no difference for some just not from what I heard.
Indeed there are blind tests done where people could not tell the difference between high end and low end CD players.
It appears to me the key is good amplification and good speakers.
Entertaining thread this! I cannot believe the winding up that gets given out at times.
Morecambe is offline
post #184 of 423 Old 04-07-2009, 01:22 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
It's an interesting and largely a predictable outcome. At the very least it indicates that under controlled conditions the differences are quite vanishingly small. It also empowers the consumer who can make a more rational purchasing decision. That doesn't mean you have to spend the least possible but it does mean that if you're on a tight budget you can apportion your monies differently which to me means speakers. Now this doesn't mean that there aren't audibly different sounding DAC's. Not at all. For example there are those that belong to a class called NOS or non over sampling. In those the makers futz with the reconstruction filters and sometimes leave them out entirely. The net effect is all that stuff that was supposed to be filtered out gets folded back into the audible region. It becomes enriched sometimes to the point that the original signal(s) is no longer the major player. Some like it. Some would rather stick with just getting the information off the disc without mucking with it.
Chu Gai is offline
post #185 of 423 Old 04-07-2009, 01:26 PM
eljr's Avatar
Quoted: 1192 Post(s)
Liked: 9009
Just an FYI, all amps sound the same also.
ELJR's "listening" blog.
eljr is offline
post #186 of 423 Old 04-07-2009, 06:17 PM
twitch54's Avatar
troublemaker !!
twitch54 is offline
post #187 of 423 Old 04-07-2009, 10:32 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
Correct.
So? If that were true, would that really be surprising?
krabapple is offline
post #188 of 423 Old 04-07-2009, 10:35 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
demonstrating that only a fool or a troll would say *all* amps sound the same.
post #189 of 423 Old 04-08-2009, 08:16 AM
Zues's Avatar
I guess to me it is. I always thought the analog connection was a little warmer sounding vs digital. But after this thread and my own testing on my system the digital connection is actually sounding better to me. The analog connection now seems to have a very slightly higher output and does not seems as clean overall. Still very close but i think i like the digital connection better now. Could be because of the dacs, or the connection, i can't say.
Zues is offline
post #190 of 423 Old 04-08-2009, 08:19 AM
Zues's Avatar
Well according to the Richard Clark test, as long as the amps are not clipping and the amps are putting out the same watts, and are level matched, nobody can pass his blind test on picking which amp sounds better. I think it comes down to a memory test more than picking which sounds better which is designed for you to fail, but he might be right. I personally think all amps sound different.
Zues is offline
post #191 of 423 Old 04-08-2009, 08:29 AM
ccotenj's Avatar
Liked: 101
yes. and richard clark is correct.
however, that doesn't equate to "all amps sound the same"...
- chris
ccotenj is offline
post #192 of 423 Old 04-08-2009, 08:39 AM
Zues's Avatar
What's it equate to then?
Zues is offline
post #193 of 423 Old 04-08-2009, 08:55 AM
eljr's Avatar
Liked: 9009
As a new and devote member of the "earth is flat" club it is imperative to point out that in a "three blind mice" test, all amps sound the same.
eljr is offline
post #194 of 423 Old 04-08-2009, 08:58 AM
ccotenj's Avatar
Liked: 101
re-read your post, it's not difficult to figure out... you posted all the information you need to figure out your question...
- chris
ccotenj is offline
post #195 of 423 Old 04-08-2009, 09:12 AM
Zues's Avatar
The test is either trying to prove all amps sound the same, OR nobody can pass his blind test. So people will look at the test and think differently. Do all amps sound the same? Or when similar amps and watts-level matching are in place, nobody can pass the blind test and they DO sound the same. So what's a consumer suppose to think about the test? Obviously if you can't pass the test they all sound the same. If you don't think so you can choose the amps and try to pass it.
Zues is offline
post #196 of 423 Old 04-08-2009, 09:17 AM
ccotenj's Avatar
Liked: 101
are you REALLY this dense?
read your post... note the parts about "non clipped, etc."...
if you don't figure it out after reading this information repeatedly, then i'm afraid there's nothing that can explain it to you....
a "valid" test (like richard clark's, for example) is significantly more involved than you perceive it to be, and given the fact that you are struggling wrapping your arms around the "all amps sound the same" conundrum/issue, i don't think it's worth the effort to try and explain it to you...
- chris
ccotenj is offline
post #197 of 423 Old 04-08-2009, 09:25 AM
Zues's Avatar
Well i don't think you can explain it. But you contradicted yourself when you said richard clark is right, but it 'doesent' equate to all amps sound the same. Sorry, but that is what the test is suppose to be about. They DO sound the same given the same watts,level matching, and non clipping. And you can't prove they do not sound the same with blind tests.
Zues is offline
post #198 of 423 Old 04-08-2009, 09:46 AM
geekhd's Avatar
Think of the term "audibly indistinguishable".
geekhd is offline
post #199 of 423 Old 04-08-2009, 11:26 AM
ccotenj's Avatar
Liked: 101
ok...
first, i am FIRMLY in the objectivist camp... i believe in the results of blind testing, ascribe no mystical crap to wire, etc.
second, a yes and a no:
yes, richard clark is correct...
no, i did not contradict myself...
third, a short explanation:
the objectivist position is in line with richard clark's test. the common subjectivist response to this is to mischaracterize the objectivists position as being "all amps sound the same", while conveniently forgetting about the caveats attached to that statement.
fourth, to restate:
all level matched, non-clipped, etc. amps will sound the same. however, from that, one cannot draw the conclusion that "all amps sound the same"...
NOW do you understand? i hope so, because my forehead is fighting a bloody battle with the brick wall...
and, yes, i'm more than capable of explaining the proper methods of testing... if you'd bother to do a bit of research (you won't even have to leave avs, it's all here in many many posts), you would be too...
- chris
ccotenj is offline
post #200 of 423 Old 04-08-2009, 02:19 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
Could be imaginary, too.
post #201 of 423 Old 04-08-2009, 02:24 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
Quite so, and my point is that that's not the same as blankly claiming "all amps sound the same". Only a fool or a troll would present that claim unvarnished...typically we find it emanating like a bad smell, from foolish or trollish 'subjectivists' (cough*eljr*cough) seeking to misrepresent or satirize the 'objectivist' view.
post #202 of 423 Old 04-08-2009, 06:10 PM
twitch54's Avatar
So..............what does all this horse crap have to do with the Op's original question ?????
twitch54 is offline
post #203 of 423 Old 04-08-2009, 06:52 PM
Zues's Avatar
Doubt it. This is the difference between direct A/B and blind testing. I don't think nobody will disagree direct A/B, fast switching, is a superior way to test than blind testing.
Zues is offline
post #204 of 423 Old 04-08-2009, 06:59 PM
Zues's Avatar
Or can we draw the conclusion they all sound the same 'even' if everything is all level matched, non-clipped etc. Only in blind testing we can say it's true.
Zues is offline
post #205 of 423 Old 04-08-2009, 07:01 PM
Zues's Avatar
Thanks for your contribution. I think we can figure out we have strayed off topic. Thanks for the enlightment.
Zues is offline
post #206 of 423 Old 04-08-2009, 08:05 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Assuming your double negative is unintentional, I'll disagree. Any "testing" that isn't blind is next to worthless. A blind fast-switching test is most reliable, contra audiophile myth.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #207 of 423 Old 04-08-2009, 10:05 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
I think I need someone to diagram that last sentence.
If you're saying that sighted A/B testing is superior to blind testing, you've entered a big 'ol world of *wrong*.
post #208 of 423 Old 04-08-2009, 11:34 PM
Zues's Avatar
Ohh well you can't convice anybody of anything. Direct A/B switching blows away any blind testing. You eliminate many factors like memory with direct a/b switching. Take for instance the stereo shop that has receivers all hooked up for A/B. I listened to a denon receiver vs a Sony receiver. Switching back and fourth easily showed the sony had much more bass and dynamics, and the denon had terrible bass, but more detail. Now if i did that with blind testing it would be much more difficult. There's always somebody that will refute any claim. I have no problems saying denons suck with bass based on direct a/b switching.
Zues is offline
post #209 of 423 Old 04-09-2009, 04:15 AM
ccotenj's Avatar
Liked: 101
no. you can't. i'm sorry that we can't get that through to you. there's a very simple reason why we can't draw that conclusion.
a blind test that shows "level matched, non-clipped, etc. amps" sound the same does not allow you to make the blanket statement of "all amps sound the same"... sorry, but when you drop the constraints of the test, you can't draw any conclusions from it...
- chris
ccotenj is offline
post #210 of 423 Old 04-09-2009, 04:18 AM
ccotenj's Avatar
Liked: 101
wow... just wow...
yup... i'd say "entered a big ol' world of wrong" pretty much sums it up... well... actually "remaining in a big ol' world of wrong" is probably more correct, given the rest of the posts...
this whole discussion is similar to your "i KNOW what an accurate picture looks like even though i've never seen one" routine...
hey, you can believe whatever you want... just be aware that your "beliefs" have no grounding in "fact"... that's NOT to say your "beliefs" are right or wrong... but it is saying that you have no evidence to back them up... so be it...
- chris
ccotenj is offline
Reply CD Players & Dedicated Music Transports
