DSD over HDMI - Players - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 235 Old 07-14-2010, 12:11 AM - Thread Starter
msilverz's Avatar
I've been traveling for a couple of months and so I haven't been able to keep an eye out for new players that will transmit DSD or high-resolution PCM from SACDs over HDMI. The only one I know of is the just-accounced Sony ES Blu-Ray player. I'll add it to the list at the top of this thread when it's listed on Sony's website. Any others?
Matty
msilverz is offline
post #122 of 235 Old 07-14-2010, 07:39 AM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Matty
Ayre DX-5
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #123 of 235 Old 07-14-2010, 10:34 AM - Thread Starter
msilverz's Avatar
Originally Posted by Kal Rubinson View Post
Ayre DX-5
Grazie!
Matty
msilverz is offline
post #124 of 235 Old 07-31-2010, 11:31 AM - Thread Starter
msilverz's Avatar
If I'm reading the manual correctly (p. 49), it looks like Marantz's new universal player, the UD5005, will--unlike it's slightly older and much more expensive cousins, the UD8004 and UD9004--output both DSD and high-resolution PCM.
Can anyone confirm?
Matty
msilverz is offline
post #125 of 235 Old 07-31-2010, 11:55 AM - Thread Starter
msilverz's Avatar
A little more research has revealed that there are two new Marantz universal players, the UD5005 and the UD7005. Along with these are two new Denon universal players, the DBP-1611UD and the DBP-2011UDCI. These Denon and Marantz players look to be clones of each other. The manual for the less expensive Denon is basically identical to the manual for the less expensive Marantz player. All appear to output DSD and high-resolution PCM over HDMI, and so I'll be adding them to the list, unless others have more information.
Matty
msilverz is offline
post #126 of 235 Old 11-15-2010, 10:38 AM - Thread Starter
msilverz's Avatar
I've added a few new players: the new Yamaha universal player, the new Oppo, and the Denon anniversary model. Any others out there that I've missed?
Matty
msilverz is offline
post #127 of 235 Old 11-16-2010, 04:08 AM
bradman's Avatar
Quoted: 17 Post(s)
Liked: 26
The Sony BDP-S*70 players will transmit DSD over HDMI.It is a selectable option in the menus.My Yamaha receiver indicates "DSD" during playback.
bradman is offline
post #128 of 235 Old 11-16-2010, 07:22 AM - Thread Starter
msilverz's Avatar
Three Sony BDP-S*70 players are already included in the list at the beginning of this thread.
Matty
msilverz is offline
post #129 of 235 Old 11-16-2010, 09:30 AM
Quoted: 678 Post(s)
Liked: 461
Matty-
It would be of interest to me to get another piece of information: What is the output resolution of these players when sending PCM from an SACD? I can contribute some numbers towards that but a wider collection would be great.
Kal Rubinson
post #130 of 235 Old 12-05-2010, 09:10 PM - Thread Starter
msilverz's Avatar
Matty-
I would be interested in that too, Kal. I don't know how much help I'll be able to be, though. Most of the research that produced this thread involves reading user manuals and unit specifications. And unfortunately, user manuals rarely specify the resolution of the PCM output from SACDs. If they say anything, it's usually just that it's "high resolution" (and so presumably higher than redbook CD resolution).
I'll see what I can find, though!
Matty
msilverz is offline
post #131 of 235 Old 12-05-2010, 09:21 PM - Thread Starter
msilverz's Avatar
For instance, the user manual for the new Marantz UD5005 does not specify the resolution of the PCM that is output from SACDs. It does say this:
"Contents of DTS-HD MA 5.1ch/192 kHz are output as 5.1ch/96 kHz [PCM, when Bitstream is set to Off]."
Can we safely infer from this that the UD5005 cannot output multichannel PCM at a resolution higher than 96 khz, and that therefore SACDs are output at that resolution as well? I have no idea.
At the back of the manual, there is this list of specifications:
Audio output characteristics
Frequency response
BD (Linear PCM)
2 Hz - 22 kHz (48 kHz sampling)
2 Hz - 44 kHz (96 kHz sampling)
2 Hz - 88 kHz (192 kHz sampling)
DVD (Linear PCM)
Super Audio CD
2 Hz - 40 kHz
Can you help me interpret this?
Matty
msilverz is offline
post #132 of 235 Old 12-06-2010, 11:07 AM
Quoted: 678 Post(s)
Liked: 461
Frequency response
BD (Linear PCM)
DVD (Linear PCM)
Super Audio CD
2 Hz - 40 kHz
Matty
Nope. The information is not there to be mined.
Kal Rubinson
post #133 of 235 Old 12-06-2010, 10:47 PM - Thread Starter
msilverz's Avatar
Kal, am I right in thinking that although the Oppo converts DSD to PCM at 88 khz, it can actually upsample that to 192 khz PCM before passing it over HDMI? If so, how would you recommend I list the Oppo on the first page?
Matty
msilverz is offline
post #134 of 235 Old 12-06-2010, 10:59 PM - Thread Starter
msilverz's Avatar
The manual for the Pioneer DV-58AV says:
"The HDMI connection is compatible with 2 channel linear PCM signals (44.1 kHz to 192 kHz, 16 bit/20 bit/24 bit), and Dolby Digital, DTS, MPEG audio bitstream, multi channel DSD, and multi channel linear PCM signals, (5.1 channel signals up to 96 kHz, 16 bit/20 bit/24 bit)."
From this is seems safe to assume that multichannel PCM from SACDs is output at 88.2 kHz. Do you agree?
I've started added the bitrate details to the first post. Any help you can provide would be great!
Matty
msilverz is offline
post #135 of 235 Old 12-07-2010, 07:12 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Matty
There is no player that upsamles from 88 to 192. Actually it only makes sense to convert DSD to either 88 or 176 PCM. Any other sample rate significantly increass required computing power. 176 does not have much of advantage over 88, since bandwidth over 45kHz is not very usable due to significant increase of noise floor in DSD encoded signal after 50kHz mark.
ap1 is offline
post #136 of 235 Old 12-07-2010, 07:29 AM
Quoted: 678 Post(s)
Liked: 461
It neither upsamples nor outputs 176.4 or 192 PCM from SACD via HDMI. 88.2 only.
Kal Rubinson
post #137 of 235 Old 12-07-2010, 09:24 PM - Thread Starter
msilverz's Avatar
Got it. Does the same go for all of the players built on the Oppo base (Ayre, Cambridge, Lexicon)?
Matty
msilverz is offline
post #138 of 235 Old 12-08-2010, 09:45 AM
Quoted: 678 Post(s)
Liked: 461
got it. Does the same go for all of the players built on the oppo base (ayre, cambridge, lexicon)?
Matty
afaik.
Kal Rubinson
post #139 of 235 Old 12-08-2010, 01:51 PM - Thread Starter
msilverz's Avatar
Someone on the Sony BDP-S570 thread reported that the Sony outputs 176.4 kHZ PCM to his Yamaha receiver. I'm going to assume that the other S_70 series players do as well.
Matty
msilverz is offline
post #140 of 235 Old 12-08-2010, 02:03 PM
Quoted: 678 Post(s)
Liked: 461
If you do, you should somehow indicate the difference between an eye-witness report and your inference in the chart.
Kal Rubinson
post #141 of 235 Old 12-12-2010, 10:29 PM - Thread Starter
msilverz's Avatar
I've added the new Sony ES Blu-Ray player to the list, which can also (I have confirmed) send PCM at 176.4 kHz.
Matty
msilverz is offline
post #142 of 235 Old 12-22-2010, 03:20 AM
hcolon's Avatar
Matty
How about this one?
http://us.marantz.com/Products/3227.asp
Herb
hcolon is offline
post #143 of 235 Old 12-22-2010, 03:25 AM - Thread Starter
msilverz's Avatar
Originally Posted by hcolon View Post
How about this one?
Herb
Thanks! I guess the UD7005 (on my list) was canceled. I'll make the change.
Matty
msilverz is offline
post #144 of 235 Old 01-04-2011, 11:14 AM
ninogui's Avatar
hello
I have been reading this post very closely as it matters a lot to me
So what about the denon olders series 1940/2910/2930 that got raved reviews ?
correction: I see now in
http://groups.google.com/group/surro...digital-output
that 1940 and others do not have dsd over hdmi. This is becoming a hard choice of a player that can give you the choice of both dsd over hdmi or analog 5.1 out. I guess I will be looking for a chepie pioneer dv-610 to replace my dv-696..
rgds
ninogui is offline
post #145 of 235 Old 01-10-2011, 09:43 AM
hifichip76's Avatar
Quoted: 23 Post(s)
FYI- My Sony 5400ES outputs SACD as 176.4 PCM over HDMI to my Marantz avr7005 pre/pro, since the Marantz does not decode DSD. This is probably for the best, since the 5400 is an amazingly good sounding machine. I think it will output DSD if it senses a pre/pro that can take it.
I can also tell you first hand that the Sony S-570 can output dsd directly and it TRIES to output 176.4 pcm to my Marantz, but it keeps dropping in and out. I'm not sure which unit is at fault, but since the Sony ES machine does it fine...
hifichip76 is offline
post #146 of 235 Old 01-18-2011, 04:54 AM - Thread Starter
msilverz's Avatar
McIntosh has a universal player (MVP881) that presumably sends both DSD and PCM over HDMI from SACDs. I couldn't download the manual, though, and so until I get some sort of confirmation, I'm going to leave it off the list.
Matty
msilverz is offline
post #147 of 235 Old 01-18-2011, 12:21 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
My Yamaha receiver is reporting PCM 176.4 kHZ from my Sony BDP-S370 with SACD.
kiwi2 is offline
post #148 of 235 Old 01-25-2011, 08:47 AM
ninogui's Avatar
and in fact mad on this issue!
Let see if you guys (and dear Kal from whom´s articles I have been feeding my brain with) can help me make sense of this situation.
Based on what I read here I went chasing a pioneer dv-58 (it´s the european dv-lx50) and grabbed one. Afterwards, and of course after reading a few brand´s receivers manuals I got a good bargain on a pioneer elite vsx-33 (mine is of course the european vsx-2020), mostly based on its manuals decoding chart
http://i177.photobucket.com/albums/w...020_matrix.jpg
so to be able to have dsd to analog direct decoding. But! whatever I do I can only achieve the status dsd->pcm, 88.2Khz from my hybrid sacd´s! what a bummer!
You will notice on the vsx-2020 chart, down end, if the surround backs are not connected straight decoding can be achieved. Well, because I am bi-amplifying the front speakers, and because to bi-amplify on the vsx the surround backs have to output to the front speakers medium range (the regular vsx outs go to the front tweeters) my surrounds are in fact connected! but of course on the vsx setup the system is defined as "bi-amplified"
Still wasn´t able to disconnect the bi-amplify/medium drivers/surround back to make the final test but somehow I doubt this will be the case!
on the avforums a nice guy came up with this, and I quote
IMHO the old VSX AX-4AVi converts the DSD to analog directly without conversion DSD->PCM. But only using the fantastic PQLS jitter free i-LINK connexion.
When it uses the HDMI CONNEXION, I think that all Pioneer AVs convert DSD signal into PCM (88,2 or 176,4 KHz).
If you wish the "best possible conversion from DSD to analog" you need to use a pair "old" SACD-AVR connected by i-link. Unfortunately, Pioneer not use this now
Now we all know the dv-58 does not have pqls mode.. and who cares in fact pioneer seem to have some of the lowest jitter of all on hdmi, take a look at
http://forums.slimdevices.com/showth...t=59207&page=2
but the vsx does get dsd from the dv-58 because at least "dsd->pcm" lights up.
What do you make of all this? What am I doing wrong ? or
- is this a case of a firmware bug on the pioneer vsx-2020 ? or
- is this a case of misleading user manual info in which case I was fooled and wrongly bought the vsx?
thks in advance
ninogui is offline
post #149 of 235 Old 01-25-2011, 09:05 AM
ted_b's Avatar
Ninogui,
I think your assessment that the use of the surround amps (regardless that they are not being used as surrounds) is likely the culprit.
HOWEVER, and please don't take this the wrong way....why do you feel that the level of equipment being used here (especially the receiver's analog stage) would allow for any real determination between pure DSD and 24/88.2k PCM? I think you are chasing a ghost. I love DSD as much as the next guy (I run a hirez music forum and am constantly being called a schill for SACD, etc), but the subtle differences are most likely negated when passed through the average receiver's opamp-based analog stage. Additionally, any pure DSD processing removes your ability to bass manage, etc. My $.02 I think you'll like the 24/88 sound, frankly. The variables are much more in the recording quality (i.e some SACD's suck, some redbooks suck, some DVD-A's suck, some hirez downloads suck).
"We're all bozos on this bus" - F.T.
ted_b is offline
post #150 of 235 Old 01-25-2011, 10:49 AM
ninogui's Avatar
hello Ted
Thank you for the quick reply,
I really understand what you mean. This reminds me of the cables cobra fat going on and on for marketing hype, where a lot of companies wish us to believe that a 1 meter $1000 audio cable will get us light years ahead in audio listening experience than a simple and good $100 audio cable. Maybe the influence is 0,0003%... I just don´t buy into that nonsense, but a lot of good folks do!
Also have a couple of sacd like police´s synchronicity and ghost in the machine that are simply.. crap! but have a dozen classical of london symphony orchestra from centurion music that are simply..amazing! as well as a few chick corea´s and so forth
My assessments just come from a simple fact, or should I say component, the main one (my ears) regarding my previous setup: a sacd pioneer dv-696 (worth $70) paired with a rather old pioneer vsx-d510 (worth $100) connected on 5.1 analog outputs and it sounded more lively and extended than my present setup (of course I have no access to complex audio evaluation machinery)
Maybe it´s me trying to recreate the perceptive/personal audio experience I had before with a more up to date and expensive setup, not having access anymore to analog outputs.. (yellow grin laugh here)
Anyway I should go and test what we both think the culprit is. If it works I will try to evaluate which one is better for me: the direct dsd decoding versus bi-amped front speakers. If it does not work I will blame pioneer (rewind: the decoding matrix posted above) for wrong information, and mind me I am a big fan of pioneer!
ninogui is offline
Reply CD Players & Dedicated Music Transports
