DSD over HDMI - Players - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 235 Old 11-16-2011, 12:28 PM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
Add 176.4 PCM for the Yamaha BD-A1010.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #182 of 235 Old 11-17-2011, 04:45 AM - Thread Starter
msilverz's Avatar
Done.
Did you receive my email, Kal?
Matty
msilverz is offline
post #183 of 235 Old 11-17-2011, 11:50 PM
drSeehas's Avatar
88.2 kHz confirmed for DSD to PCM conversion in Pioneer BDP-53FD/BDP-LX55:
http://www.avsforum.com/avs-vb/showt...5#post21226715
drSeehas is offline
post #184 of 235 Old 12-19-2011, 12:26 AM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
I have a Sony BDP-S380 player that I am sending DSD to my Onkyo 805 receiver (Burr Brown 24/196 DAC) via HDMI. When I check the receiver it indicates it is receiving a 44.1 signal, not the high resolution one would expect from SACD.
I have tried every conceivable setup feature for both the player and the AVR to no avail. Anyone else using an 805? I realize it is a few years old but I see no need to upgrade anytime soon.
Nothing is ever as easy at it should be!
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #185 of 235 Old 12-19-2011, 12:59 AM
drSeehas's Avatar
Originally Posted by NWCgrad View Post
... Sony BDP-S380 player ... sending DSD to my Onkyo 805 receiver ...
You mean the TX-SR805?
... indicates it is receiving a 44.1 signal ... I have tried every conceivable setup feature for both the player and the AVR ...
Really?
In the S380 Audio Settings the "DSD Output Mode" is set to "On"?
In the S380 Music Settings the "Super Audio CD Playback Layer" is set to "Super Audio CD"?
Is there any other device in the HDMI chain?
drSeehas is offline
post #186 of 235 Old 12-19-2011, 04:32 AM
NWCgrad's Avatar
Liked: 1311
Really?
Yes, the TX-SR805 but the player is the Sony BDP-S480.
DSD output mode is set to "On" and playback layer is set to SACD. No other devices in the chain (Sony BDP-S480 --> [HDMI] --> Onkyo TX-SR805 --> [HDMI] --> BenQ PE7700 projector).
Tried multiple SACDs and front display shows DSD/2.0 or 5.1 (disc dependent)/44.1 kHz. SACDs sound good through the system, but I may have to dig out my RCA cables and use the analog output (I can't imagine it will be all that good in a $100 BluRay player).
Any help from the experts would be greatly appreciated. I am thinking about getting a file server soon (such as the Auraliti PK100/90 [PK100 reviewed at http://www.computeraudiophile.com/co...Player-Review]) and a new DAC (Peachtree Audio DAC•iT or Schiit Bifrost) in a few months.
Home Theater:
NWCgrad is offline
post #187 of 235 Old 12-19-2011, 06:19 AM
drSeehas's Avatar
... No other devices in the chain (Sony BDP-S480 --> [HDMI] --> Onkyo TX-SR805 --> [HDMI] --> BenQ PE7700 projector).
So, there IS another device in the chain: The BenQ PE7700 projector.
I know neither the Onkyo TX-SR805 nor the BenQ PE7700 projector.
You could try the following (only for testing):
  • Switch off the BenQ PE7700 projector (not standby, to be sure, unplug the power cable) or unplug the HDMI cable between receiver and projector at your choice.
  • Switch off the receiver and the player.
  • Switch on in the following order!: 1st receiver, 2nd player.
  • Don't switch on or connect the projector!
  • Now try to play a SACD. What does the display show now?
Maybe you ask in the Onkyo TX-SR805 thread, what other users get on their display with SACDs.
... front display shows DSD/2.0 or 5.1 (disc dependent)/44.1 kHz...
This doesn't make sense as DSD is 2.8224 MHz.
Either you receive PCM with 44.1 kHz or DSD with 2.8224 MHz.
... but I may have to dig out my RCA cables and use the analog output (I can't imagine it will be all that good in a $100 BluRay player).
Yes. The DAC in the receiver is better than the DAC in the Sony 480 player. Waste of time.
drSeehas is offline
post #188 of 235 Old 12-19-2011, 06:44 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
805 as well as other Onkyo's of that time - 875, 905, can work with DSD. I do not know where you got 44.1, if from service display, than you are right, it converts DSD to PCM at 44.1 for DSP (like Audissey) processing. You can choose Direct mode if you want DSD passed directly to DAC without any processing.
ap1 is offline
post #189 of 235 Old 12-20-2011, 06:38 PM
NWCgrad's Avatar
Liked: 1311
drSeehas and ap1, thank you for your input it is greatly appreciated.
I removed the HDMI cable to the BenQ and set the receiver to HDMI Output = OFF. Unplugged to reset and tried again. Still shows up in the display screen as Fs = 44.1 kHz (documented in the attachment - sorry about the incredibly poor quality picture but the important information can be read).
I tried the Pure and Direct mode, same display. Perhaps the display is incorrect, as it shows it is a DSD stream and not PCM.
Home Theater:
NWCgrad is offline
post #190 of 235 Old 12-20-2011, 07:14 PM
Kilian.ca's Avatar
Liked: 37
Nothing wrong. See this for an explanation of what the fs value is.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #191 of 235 Old 12-20-2011, 07:39 PM
NWCgrad's Avatar
Liked: 1311
Thanks for the link, that clears things up!
Home Theater:
NWCgrad is offline
post #192 of 235 Old 12-22-2011, 09:41 AM
ninogui's Avatar
hi guys
On the Cambridge 751BD,
According to this tester here (in french) if we follow the analog path it always translates into pcm because of the wolfson 8740, also from what he says for PCM we can assume it goes up to 176KHz
http://www.hdfever.fr/2011/11/11/tes...e-audio-751bd/
"Par contre, un des points assez décevants sur ce Cambridge vient du fait que les DACs Wolfson ne gèrent pas le DSD. Si vous décidiez de lire le Super Audio CD en connexion analogique vers un intégré ou sur un ampli AV en bypass (car il n’y a pas de contrôle de volume sur ce lecteur, donc pas d’ampli de puissance relié directement), vous serez obligé de convertir le DSD en PCM, et vous perdrez donc tout l’intérêt de la numérisation du DSD en 1 bits / 2.8 Mhz qui propose ce timbre si chaleureux et cette spatialisation et localisation des musiciens propres au Super Audio CD. Dommage !
Quoi qu’il en soit, la qualité de la conversion DSD/PCM/Analogique est tout de même excellente avec un DSD converti en 176.4 khz / 24 bits, puis en analogique avec la qualité des DACs Wolfson que l’on vient de voir."
ninogui is offline
post #193 of 235 Old 12-22-2011, 09:50 PM
Kilian.ca's Avatar
Liked: 37
According to this tester here (in french) ... from what he says for PCM we can assume it goes up to 176KHz
Assumption isn't sufficient. Usually the receiver's front display shows the sample rate of the incoming PCM via HDMI. We need some one to see it happening at least.
The DSD-PCM-analogue decoding isn't the topic of this thread but usually it is unknown unless there is official documentation, an info OSD showing the sample rate or a means to capture the PCM inside and analyse it. The HDMI output is a pointer but only a pointer. The CA 751 does upsampling to 24/192 for the analogue outputs as its major selling point and I don't know if this applies to SACD.
post #194 of 235 Old 12-27-2011, 10:23 AM
bmwetr's Avatar
Last week I acquired a Sony BDP-S480. I am only using it to play SACDs. I have it set to output DSD via HDMI to my Denon AVR-2809. The DSD indicator illuminates on the Denon, as do each of the 5.1 input channel indicators. The sound is pristine. I cannot perceive any difference from the Oppo-BDP93 that preceded it.
So, my question is; if you are only using a player to read an SACD and pass a DSD Signal to an AVR where the sound is decoded, is there any audible reason to spend more for a higher quality player? It would certainly look better, be built stronger, and probably last longer. Other than that, should I/we care? I am using a Panasonic DMP-BTD310 for Blu-Ray, as I need dual HDMI outputs.
Denon AVR-2809
Pioneer Elite 141-FD
Dahlquist 9c mains
Pinnacle center & surrounds
Panasonic DMP-BTD310 (for DVDs)
Sony BDP-S480 (for SACDs)
bmwetr is offline
post #195 of 235 Old 12-27-2011, 11:12 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
No, there is no real difference. You use player as a transport only, so DAC and analog part in it (which might make a difference) is bypassed.
ap1 is offline
post #196 of 235 Old 04-04-2012, 07:24 AM - Thread Starter
msilverz's Avatar
I added the new Primare universal player and cleaned up the list in a few other respects. I assume that since the Primare is also based on the Oppos, it outputs PCM over HDMI at only 88.2 kHz. Until that's confirmed, though, I'll leave it unspecified.
Matty
msilverz is offline
post #197 of 235 Old 04-05-2012, 01:00 AM
drSeehas's Avatar
What about the new Sony BDP-S390, -S490, -S590 and -S790?
drSeehas is offline
post #198 of 235 Old 06-14-2012, 10:15 AM
destrizz's Avatar
My onkyo 875 receiver is reporting 44.1 kHZ from my Sony BDP-S590 with SACD...smile.gif
Confirm SACD-R
Edit: firm .369 remove SACD-R mad.gif
destrizz is offline
post #199 of 235 Old 06-29-2012, 09:28 PM
silvereyes's Avatar
Any update about these players?
silvereyes is offline
post #200 of 235 Old 07-01-2012, 03:47 AM
glangford's Avatar
Quoted: 315 Post(s)
Liked: 254
Page one of this thread has the current update. The sony players you mention are all capable of 176 khz pcm.
glangford is offline
post #201 of 235 Old 07-04-2012, 07:33 AM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
The Sony 5400ES is available again. There are a few dealers on Audiogon and eBay selling them. I just picked one up with build date APRIL 2012! biggrin.gif
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #202 of 235 Old 07-17-2012, 06:12 PM - Thread Starter
msilverz's Avatar
Thanks for the surprising but great news! I've moved the 5400ES out of the "discontinued" lists!
msilverz is offline
post #203 of 235 Old 09-22-2012, 09:52 PM - Thread Starter
msilverz's Avatar
I've added some new players from a few of the larger manufacturers (Denon, Oppo, Pioneer), and I've moved a few items into the discontinued lists. If you know of any further additions or have some corrections, please let me know!
msilverz is offline
post #204 of 235 Old 09-25-2012, 04:16 AM
glangford's Avatar
Quoted: 315 Post(s)
Liked: 254
I'd move the oppo 93 to discontinued as well. Only refurbs are available.
post #205 of 235 Old 09-25-2012, 01:27 PM
gbaby's Avatar
Quoted: 657 Post(s)
Liked: 264
At least the incompetent folks in Sony marketing came to their senses.wink.gifcool.gif
gbaby is online now
post #206 of 235 Old 09-26-2012, 06:12 AM - Thread Starter
msilverz's Avatar
Done!
msilverz is offline
post #207 of 235 Old 02-23-2013, 06:15 AM
jfbar1's Avatar
Bumping this thread for anyone still interested in the topic. Been a little disapointed in (now both) of my Oppo's regarding DSD. My first bdp-83 would NOT pass DSD unless it was DISCONNECTED from the TV (Sharp LED). Even then after MUCH comparisons, my Sony bdp-s770 would not only pass the DSD (to my Onkyo NR809), but sounded MUCH better overall to me. I actually could NOT tell much audible difference between DSD out of the Oppo and decoded PCM. I still do listem to my (few) 2 channel stero SACD's on the OPPO as the decoding to PCM actually add's a little "punch" to an otherwise weak sounding mix compared to the DSD stream.
I just hooked up my new bdp-103. SAME result as the 83. At this point, I will just rely on the Sony for the DSD surround playback and the OPPO for everything else.
Not to knock the Oppo, and I realize that SACD is a pretty much niche format (I sought out the Onkyo just to get the DSD decoding over HDMI as MOST all of the current AVR's do not support it anymore). It just that the OPPO's are held in such high regard, the SACD support does not compare (IMO) to the Sony's.
jfbar1 is online now
post #208 of 235 Old 02-23-2013, 06:27 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
There is one advantage Oppo has over Sony - it plays SACD-R disks. None of Sony players do it.
ap1 is offline
post #209 of 235 Old 02-23-2013, 09:17 AM
Quoted: 802 Post(s)
Liked: 567
Which HDMI output are you using?
Kal Rubinson
post #210 of 235 Old 02-23-2013, 09:46 AM - Thread Starter
msilverz's Avatar
Is there anything missing from the list on the first page?
Matty
msilverz is offline
Reply CD Players & Dedicated Music Transports
