DSD over HDMI - Players - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 235 Old 02-24-2013, 03:39 AM
glangford's Avatar
Quoted: 318 Post(s)
Liked: 255
Bump the Oppo-95 down to disconintued.
glangford is offline
post #212 of 235 Old 02-24-2013, 10:11 AM - Thread Starter
msilverz's Avatar
Done. Thanks!
msilverz is offline
post #213 of 235 Old 03-03-2013, 03:34 AM
jfbar1's Avatar
Originally Posted by Kal Rubinson View Post
Which HDMI output are you using?
Finally swung the rack around to do some wire management (and hook up my Sony S770 as it is probably going to be my reference SACD DSD transport). I DID have the OPPO hooked up to HDMI 1. swapped it around so the TV is output 1 and the Onkyo is HDMI2. have not tried it yet, but am very interested to find out if it will be better than the BDP83.
It seems that even the player is outputting straight DSD, the actual sound can vary wildly. I proved this with my BDP83 vs S770 vs (Pioneer) 48DV shootout a few months back.
jfbar1 is offline
post #214 of 235 Old 03-03-2013, 08:17 AM
Kal Rubinson's Avatar
Quoted: 804 Post(s)
Liked: 569
HDMI 2 is better for audio as it does not go through the Qdeo video processor.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #215 of 235 Old 03-04-2013, 01:48 PM
Quoted: 804 Post(s)
Liked: 569
Originally Posted by AVfile View Post
So you preferred 176/16 (Sony) to 88/24 (Oppo)?!
Neither of those are DSD.
Kal Rubinson
post #216 of 235 Old 03-04-2013, 01:50 PM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #217 of 235 Old 03-12-2013, 04:34 PM
jfbar1's Avatar
Update 2 I got to try out both the OPPO and the Sony in kinda a shoot out. First off, I was very pleased to finally get DSD out of the OPPO and it sounded great. I had both running HDMI into my NR809 in "Pure Direct" mode.
After several switching of the SACD (Elton John-Honky Chateau) I still have a slight nod toward the Sony. It seems to kick up the center channel just enough to really bring out the vocals in the song (not that he has the best singing voice LOL) and sounded just a little bit more "full" than the OPPO.
On the other hand, the conversion to PCM with stereo SACD's sounds much better than direct DSD.
jfbar1 is offline
post #218 of 235 Old 03-15-2013, 10:40 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1771
jfbar1,
What Onkyo receiver do you have?
I was wondering if you've tried listening with Audyssey enabled. Some receivers are unable to apply Audyssey to DSD or very high bitrate LPCM.
Selden
Selden Ball is offline
post #219 of 235 Old 03-15-2013, 10:55 AM
Liked: 1771
It's probably time to consider moving the Sony BDP-S390 and -S590 to the discontinued column, replacing them by the BDP-S5100. Unfortunately, the manual for the -S3100 does not mention any SACD or DSD support. Both are mentioned in the -S5100's manual, but the bitrate of the LPCM conversion isn't specified.
Selden
post #220 of 235 Old 03-15-2013, 04:09 PM
jfbar1's Avatar
Originally Posted by Selden Ball View Post
jfbar1,
It is a NR809. Funny story, never got the audessy to complete without errors. It sounds pretty good as is. I was more interested in comparing the DSD out of the Sony S770 with my new OPPO BDP-103. Like I said before, it was a very close race, bu tI ended up liking the Sony better. I left the AVR with the same volume and both inputs were running "pure direct"
jfbar1 is offline
post #221 of 235 Old 03-18-2013, 09:23 AM
oryan_dunn's Avatar
Quoted: 122 Post(s)
Liked: 92
I think the two Yamaha A1000 and A1010 need to be moved to the discontinued list and the A1020 be added to the current list.
http://usa.yamaha.com/products/audio-visual/blu-ray_players_and_dvd_players/blu-ray-players/bd-a1020/?mode=model
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is online now
post #222 of 235 Old 03-25-2013, 12:43 AM - Thread Starter
msilverz's Avatar
Updates to Sony and Yamaha players made. I suspect that both transmit PCM at the higher bitrate, but I won't note anything until it's confirmed. Thanks!
msilverz is offline
post #223 of 235 Old 04-23-2013, 06:50 AM
wmy5's Avatar
Originally Posted by ap1 View Post
There is one advantage Oppo has over Sony - it plays SACD-R disks. None of Sony players do it.
See this plz, http://code.google.com/p/sacd-ripper/wiki/SACDRCompatiblePlayers
Most Sony BD players work with SACD-R.
wmy5 is offline
post #224 of 235 Old 04-27-2013, 11:44 AM
jh58l's Avatar
Pioneer BDP-450 (88,2kHz, 24bit)
Regards from Germany
Jens
jh58l is offline
post #225 of 235 Old 05-01-2013, 02:14 PM - Thread Starter
msilverz's Avatar
Jens
Done. Thanks!
msilverz is offline
post #226 of 235 Old 05-15-2014, 08:45 AM
FanofHD's Avatar
Can anyone confirm what is the highest PCM rate being transmitted when playing SACD's on the Sony Blu-ray player BDP-S5100
I have an older Sony receiver that is only transmitting PCM 44.1 (because I am forced to use the coaxial cable since my receiver is only HDMI 1.0)
I'm trying to find what rate this player will actually transmit through PCM when playing SACD's.
FanofHD is offline
post #227 of 235 Old 05-19-2014, 10:43 PM
wmy5's Avatar
I have Sony BDP-S370, if PCM conversion is enabled, the highest sample rate is 176.4kHz. I think S5100 is the same.
wmy5 is offline
post #228 of 235 Old 02-24-2015, 08:01 AM
Liked: 0
If anyone from this thread(very experienced people...) could answer I would appreciate. I own Sony s480, playing sacd via hdmi output(dsd off) and through embedder(retain max output176,4 )and via coaxial finish to Arcam rdac. My amp is Naim.
SACD playback isn't as I expected..sound is poor. BD audio sound is much better.
I intend to buy ud5007. I found here, its output 176,4. but 16 or 24 bit? And in general (every opinion who is willing to respond)
1.should I have improvement in sound?
2.Do I still need a dac if I use only discs ( Marantz will conversion)?
Thanks a lot to everyone
jnikolic is offline
post #229 of 235 Old 02-24-2015, 08:27 AM
Liked: 0
SACD r is my media, that's why Im not interested for oppo. (Someone could suggest me that option)
jnikolic is offline
post #230 of 235 Old 02-24-2015, 11:55 AM
Phantom Stranger's Avatar
Quoted: 442 Post(s)
Liked: 335
If playing SACD-Rs, check this list of compatible players first:
https://code.google.com/p/sacd-rippe...patiblePlayers
The Oppo players still play SACD-R if you can get one with an older firmware. They were forced to close that loophole when it became too well known. I don't have any experience with that Marantz, someone else will have to report its output settings.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #231 of 235 Old 02-25-2015, 06:28 AM
Liked: 0
Thanks Phantom Stranger. I hope that someone will respond because here are people that really know. Additionally, I cant take Marantz with me, check sound, and eventually return. (rules...)
There was one 103 in shop, but owner use it as demonstration one, with updated firmware.
I checked Marantz and it recognized SACD-R. Info that Im looking for is, what I should expect/get with Marantz. I suppose that in any way it will convert dsd to pcm significantly better than cheap sony. SACD Sound from sony is really bad.
Im focused just on BDP because:
-DSD capable receiver with Sony as transport is out of question I have Naim amp and Im very satisfied
-dsd dac is to expensive with hdmi input + already have arcam rdac
I have dembedder so it will keep PCM signal as it is "outputted" via HDMI from BDP after conversion.
jnikolic is offline
post #232 of 235 Old 02-25-2015, 08:03 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
Frankly, I believe this may be just your perception of Sony machines based solely on their pricing structure.
I've had both the Sony BDP-S770 and now the BDP-S790 since 2010. In 2012 I invested in the Denon AVR-3313 which will process DSD bitstream.
Shortly after purchase of the Denon, I compared the sound quality between DSD bitstream and 24/176.4 PCM from the Sony S790. I could not detect any difference in sound quality whatsoever between the two formats.
Iain- is offline
post #233 of 235 Old 02-25-2015, 10:11 AM
Quoted: 442 Post(s)
Liked: 335
I would generally agree there is little difference in sound between pure DSD and DSD decimated to 24/176.4 PCM quality. Only systems in the tens of thousands would have a low enough noise floor to reveal differences between them.
It's very possible that de-embedder is introducing other issues into the sound.
post #234 of 235 Old 02-25-2015, 12:50 PM
Liked: 0
s790 is I suppose much better than mine s480. Cheap" is wrong used term - I intended to say better dac is in Marantz, better electronics at all....Certainly I didnt expect wonders.
For de-embedder I don't know what to say. I have some audio BD-Rs. I use pcm output via hdmi depend on resolution available on disc, it goes to de- embedder then via coaxial to Arcam rdac and sound is really OK.
I'm not sure what Arcam do with 24/176, for coaxial input for sure it support 24/192.
OK. I will decide for few days..I like music so much, I am trying various recordings, formats just to enjoy in good sound but I am not ready to pay for fairy tale or marketing tricks.
My appreciation for answers...
jnikolic is offline
post #235 of 235 Old 05-23-2015, 05:14 PM
mark_k's Avatar
I have been using bdp 9700 from Philips for some time. Apart from great video, it also supports SACD playback by sending bitstream to my AV7005. It sounds detailed and clear.
Mark K
mark_k is offline
Reply CD Players & Dedicated Music Transports
