Fixed or variable outputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-19-2009, 09:55 AM - Thread Starter
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
"variable outputs are almost always not as good as fixed ones" Is this a true statement? If so why. If not, why not?
eljr is offline
post #2 of 11 Old 06-19-2009, 10:48 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 458
As hedged, it is true. Many players do volume attenuation in the digital domain and actually reduce resolution as they throw away data. This is not good. OTOH, there are more sophisticated digital attenuators as well as analog attenuators in some devices that are just fine.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 11 Old 06-19-2009, 11:56 AM - Thread Starter
eljr's Avatar
Liked: 8025
Thanks for the reply, would you think a McIntosh Cd player would likely fall into the latter catagory?
eljr is offline
post #4 of 11 Old 06-19-2009, 12:31 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
Are you using any type of pre-amp? If so, I don't see any need to use the variable outputs.
WilliamZX11 is offline
post #5 of 11 Old 06-19-2009, 12:59 PM - Thread Starter
eljr's Avatar
Liked: 8025
I use the variable outputs direct to the power amps but that is besides the point, my questions are as stated.
Someone suggested that a preamp if used with a particular CD player would be preferable as it would make the sound more "musical". My understanding has always been that the sign of a good preamp is it's transparency. Hence why would one need a pre amp if a CD player has a quality pre built in?
In other words I am challenging the fact that an external preamp will add "warmth" and that if it does, it shouldn't unless you want it to.
eljr is offline
post #6 of 11 Old 06-19-2009, 01:47 PM
Quoted: 25 Post(s)
I see. I compared my old pre-amp to the CD players variable output, although it was a 1989 Sony player that used a motorized analog volume control. I could never tell any difference with or without the pre. I imagine different pre's, especially tubes, would have different results.
post #7 of 11 Old 06-19-2009, 01:54 PM
Quoted: 673 Post(s)
Liked: 458
Dunno. Ask MAC how they do it or search out reviews with tech info.
Note: ".......used a motorized analog volume control."
Kal Rubinson
post #8 of 11 Old 06-19-2009, 04:27 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
I still use my Sony CD player. 5 DSP settings. No digital outputs, and it uses a motorized analog volume control output (or fixed outputs). Memory remembers the volume control setting for each CD!
J_Palmer_Cass is offline
post #9 of 11 Old 06-19-2009, 04:42 PM
Quoted: 25 Post(s)
I believe I did note that.
post #10 of 11 Old 06-24-2009, 11:42 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
This ignores the fact that as a practical matter, volume attenuation in the analog domain also reduces resolution because it reduces the signal and makes its amplitude that much closer to the noise floor.
On balance, the noise floor in a digital system can be made as low as is desired by increasing the data word length. In the analog domain, you are pretty well stuck with the resolution limits imposed by the laws of physics.
Often the worst resolution losses in real world systems happen after the digital signal is converted back to analog.
arnyk is offline
post #11 of 11 Old 06-24-2009, 12:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
This is a question that can't have just one answer because it does not say enough about the operational sitaution.
For example, consider a device with a 24 bit digital output that of course implements attenuation in the digital domain.
Compare that to your typical piece of equipment with fixed output driving an amplifier or receiver that uses an analog volume control.
The variable output wins and not by just a little!
arnyk is offline
Reply CD Players & Dedicated Music Transports
