Sound card for hi-fi playback - AVS Forum
post #1 of 18 Old 11-14-2010, 01:26 PM - Thread Starter
pistonengine's Avatar
Hey all,
I've been using a X-Mystigue 7.1 for the longest time. I recently bought and repaired a pair of Magneplanars, and with the new speakers it's pretty obvious the sound card ain't cutting it. My setup is a 2.1 home theater system. I have a computer with the video out to TV and audio to the receiver. Music from the computer is pretty good in the low and mid ranges, but it's not very bright in the treble, especially the vocals. When I pop a CD into my blu-ray player, it makes all the difference. Little less prominent in the mid range, but makes up all the difference in the treble.
I'd like to keep playing music from the computer. Any suggestions for sound card and audio format that'll provide CD-quality sound? Currently using WMA lossless.
pistonengine is offline
post #2 of 18 Old 11-14-2010, 05:03 PM
ap1
ap1's Avatar
Something like this http://www.emu.com/products/product....&product=19169 will give you exceptional stereo sound. You also can use it to send digital stream to your receiver. Use Foobar2000 http://www.foobar2000.org/ as player and ASIO mode for best results.
ap1 is online now
post #3 of 18 Old 11-14-2010, 08:28 PM - Thread Starter
Cool beans. Do you know of any outlets that'll allow me to return a card if I don't like the sound?
post #4 of 18 Old 11-17-2010, 10:21 AM - Thread Starter
You know, I just had a thought. My sound card has digital output. If I get a decent DAC, do soundcard -> DAC -> receiver (my receiver has no digital inputs), shouldn't the computer at that point just be a really expensive optical sensor for a CD player, since the PCM won't be altered? Or will it still have processing from the soundcard?
post #5 of 18 Old 11-17-2010, 10:40 AM
EndersShadow's Avatar
Liked: 543
If your passing it out via Optical its not being touched by the computer so you are correct.
Out of curiosity what are you using to drive the Maggies? From my understanding they tend to do much better with dedicated power (i.e. a seperate amp as opposed to a reciever).
My Setup
There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #6 of 18 Old 11-17-2010, 11:08 AM - Thread Starter
using an old Sony TA-AV670. I'd be willing to look at separate amps, though I'm still very green in the whole hi-fi audio equipment. Can you point me at an example?
I'll see if i can get a hold of a decent DAC. I've tried both playing the WMA lossless and CD in the rom drive, sounds exactly the same kind of mush.
post #7 of 18 Old 11-17-2010, 12:25 PM
ap1
ap1's Avatar
Any external DAC is more expensive than card I mentioned above. And if you want DAC matching quality of that card, you should allocate close to $1000 for it.
ap1 is online now
post #8 of 18 Old 11-17-2010, 12:50 PM
Liked: 543
Would recommend going this route | Internal Soundcard - 2 channel amp - Maggies
As to what amp, it really depends on which set of Maggies you have. I would look at something that can handle 4 ohm loads or lower and I dont have a ton of experience with them, so I will defer to others to give you good recommendations on amps....
Some names I hear a lot paired with Maggies are Adacom, Parasound, Carver, Macintosh...
My Setup
post #9 of 18 Old 11-17-2010, 03:30 PM - Thread Starter
Ok I'll stick to looking at cards then. As for the amp suggestion...
something like this? http://www.adcom-usa.com/prod/shopdi...=3&prodid=1152
So do the receiver to the amp and out to the fronts? I'm a bit confused, since won't the receiver essentially be pre-amping it?
post #10 of 18 Old 11-17-2010, 05:29 PM
Liked: 543
you would go computer to amp to speaker and dont need the receiver at all.
that amp would work wonders with your speakers I believe.
My Setup
post #11 of 18 Old 11-17-2010, 05:50 PM - Thread Starter
KK but that leaves me limited to one input for the speakers. I do use them for cable and blu-ray, too.
Edit- I also have a center channel for movies. Seems like the amp will only do if the system was dedicated to music only.
post #12 of 18 Old 11-20-2010, 03:16 AM
MichaelJHuman's Avatar
Quoted: 65 Post(s)
Liked: 74
You can also go external, if the RF inside a computer is of concern.
Here's another offering by eMU. There are of course many USB audio interfaces out there.
(I looked it up a bit, and some people had problems using it with their PCs, so maybe there's newer devices out there with more compatibility)
http://www.emu.com/products/product....&product=15186
"But this one goes up to 11"
MichaelJHuman is online now
post #13 of 18 Old 11-24-2010, 08:55 AM
dear.chap's Avatar
Here is one which uses its own clock to eliminate jitter
http://halidedesign.com/bridge/
dear.chap is offline
post #14 of 18 Old 11-24-2010, 05:16 PM
ap1
ap1's Avatar
ALL sound card have their OWN clock. All FireWire and almost all USB audio interfaces have also have their own clock.
ap1 is online now
post #15 of 18 Old 11-26-2010, 06:01 PM
Blacklac's Avatar
If you have XP and are interested in a M-Audio Delta 2496, PM me. I loved the card while I used it, but moved on to the M-Audio 1010LT for 7.1.
I say XP because they are known for not supporting Win7. I'm not sure about Vista. I use XP so it never bothered me.
Blacklac is offline
post #16 of 18 Old 11-27-2010, 06:51 AM
ap1
ap1's Avatar
It seems like they DO support Win7 - http://www.m-audio.com/index.php?do=...6d60474dcb82b0
ap1 is online now
post #17 of 18 Old 11-27-2010, 04:37 PM
Blacklac's Avatar
They have drivers, but that doesn't mean they work. . If it worked on Win7, I'd have sold the card to my friend already.
Blacklac is offline
post #18 of 18 Old 12-06-2010, 12:35 AM
RobScreene's Avatar
I have a m-audio 2496 working well with win7(32-bit) media centre and foobar2000 (asio) behind for flac music playback.
Rob
RobScreene is offline
Reply CD Players & Dedicated Music Transports
User Tag List
