No CD changer....looking for options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-13-2011, 01:46 AM - Thread Starter
ducktailjiver's Avatar
Hi all,
I have a Sony 400 cd changer that is just now starting to go after 12 years of faithful service. I really dont wanna buy another changer. I have a really nice Denon Receiver and dont wanna part with it. I'm hoping there is a way I can hook up an external hard drive with my music on it to my receiver. I know I'll need a TV to scroll thru menus but that's ok. Is there a way to hook up an external Drive to my receiver even though is has no USB? What are my options?
Thanks for any info
Duck
ducktailjiver is offline
post #2 of 8 Old 03-13-2011, 08:19 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Simple but pricey are the Olive units.
Have a computer? A wireless network? That, an Airport Express, and an iPod Touch/iPhone will do the trick.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 8 Old 03-13-2011, 09:28 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
There are many options. There are all sorts of media "bridge" devices now, which can stream music off of a PC. For example, Roku Bridge (not endorsing this, just mentioning it as an example.)
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 8 Old 03-15-2011, 01:25 AM - Thread Starter
My stereo is nowhere near my PC. hummm
post #5 of 8 Old 03-15-2011, 03:40 AM
Roseval's Avatar
Quoted: 38 Post(s)
Liked: 26
If this is the case and you want it to keep that way, a streaming audio player as suggested above is the solution.
You have the audio on a PC, a NAS, what ever
You use the PC to maintain your collection.
You use a streaming media player like Sonos, Squeezebox, etc to access the audio on the PC/NAS/etc over the network.
The media player is close to the receiver and connected to it by RCA or digital.
A couple of players can be found here: http://www.thewelltemperedcomputer.com/HW/DAP.htm
Roseval is offline
post #6 of 8 Old 03-15-2011, 05:54 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Not a problem. WiFi.
mcnarus is offline
post #7 of 8 Old 03-15-2011, 06:29 AM
Kal Rubinson's Avatar
Quoted: 771 Post(s)
Liked: 542
Squeezebox Touch. Runs from WiFi or ethernet, has its own display/remote and outputs analog or S/PDIF. http://www.stereophile.com/mediaserv...yer/index.html
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #8 of 8 Old 03-15-2011, 07:47 AM
walbert's Avatar
Western Digital has a range of products, some of them will connect to a hard-drive (and do exactly what you've outlined), some will connect to your network via Ethernet or WiFi and stream from there, some have their own internal hard-drives and can stream as well; all depends on what you wanna do and how much you wanna spend.
See here:
http://www.wdc.com/en/products/products.aspx?id=330
You're also not talking about $500-$5000 "audiophile" components either.
ViewSonic and Asus also offer similar products, might be worth looking at as well.
walbert is offline
Reply CD Players & Dedicated Music Transports
