Which CD player option is best? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-13-2011, 08:18 PM - Thread Starter
tap_or_nap113's Avatar
I am buying an oppo bluray player, but I also want the best cd quality I can get. I would like some input from you guys. So far I am looking at maybe getting the BDP-93 as a transport and buying the Emotiva XDA-1 DAC, or would I be better off just getting the BDP-95 and skipping the XDA-1? Or then I thought about getting the BDP-93 for bluray and the Emotiva ERC-2 cd player for cd playback. I would like to hear from some people with experience with these products. I am on a budget, and these options seem to be some of the best in my price range.
tap_or_nap113 is offline
post #2 of 7 Old 05-14-2011, 12:31 PM - Thread Starter
Nobody has any feedback???? Hello??? I could use some help.
post #3 of 7 Old 05-14-2011, 04:54 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Go directly to the 95. It has an excellent analog section and includes balanced out. It also has a quality oversized power supply that was designed by Rotel. A+ quality in both audio & video.
Class A is offline
post #4 of 7 Old 05-14-2011, 05:57 PM - Thread Starter
Thanks for the reply. I know the BDP-95 is the best cd player; I just wonder if it's better enough to justify the cost difference over the 93 with an Emotiva XDA-1 DAC, which I could also use for other digital mediums. Any thoughts?
post #5 of 7 Old 05-17-2011, 08:51 PM
TheHills44060's Avatar
I'd go with the 95 for sure. In my book hooking up the Emotiva to either unit is waste of money and a downgrade. Now if you are talking a quality DAC then I may consider a different 93/DAC option if you need the additional inputs.
Have you considered any other DAC's?
TheHills44060 is offline
post #6 of 7 Old 05-17-2011, 10:50 PM
walbert's Avatar
The only thing I'd consider in this scenario over the Oppo is a more "old school" CD player, that offers more buttons and macros (which is something I've yet to see any LD/DVD/HD-DVD/BR player match) - to say nothing at all of quality. I just like the extra control without needing a TV or remote.
The BDP-95 looks nicer on paper than the XDA-1, and I'm always a fan of single device solutions (the less stuff you have to turn on and play with, the quicker you can get to enjoying your album/movie). Personally I'd probably get something else (well, I did), but I can agree with the BDP-95 or BDP-93 suggestion.
walbert is offline
post #7 of 7 Old 05-20-2011, 01:41 PM
bettyn's Avatar
Get the BDP-95. It's the best sounding CD or universal player I've ever heard.
bettyn is offline
Reply CD Players & Dedicated Music Transports
