Connecting a XDA-1 to a Denon AVR 988 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-30-2011, 05:12 PM - Thread Starter
layla90's Avatar
What is the best way to connect an XDA-1 to a Denon AVR 988? RCA cables to phono is what I have been seeing on some forums. I want to make sure that my AVR doesn't reprocess the analog signal.
layla90 is offline
post #2 of 4 Old 05-30-2011, 08:27 PM
runnin''s Avatar
Liked: 45
When I had my denon avr, I had the XDA connected to the multi channel input section and front left and right. Then use the avr in stereo mode only. This stops any processing by the receiver whatsoever.
runnin' is offline
post #3 of 4 Old 05-30-2011, 09:05 PM - Thread Starter
layla90's Avatar
thanks runnin....I'll try going to the multi channel connections. I am assuming that if the AL24 processing light is not on than I am in pure analog mode?
layla90 is offline
post #4 of 4 Old 05-31-2011, 06:25 AM
runnin''s Avatar
Liked: 45
Man, I can't remember now what that light signified. But if you use the multi channel inputs, you have to select that input on your remote and no processing can be done on those inputs as Denon designed it I believe.
runnin' is offline
Reply CD Players & Dedicated Music Transports
