Pioneer PD-M435 CD Player Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-19-2011, 12:12 PM - Thread Starter
rpludwig's Avatar
Pioneer PD-M435 CD Player, 6 disc cartridge changer problem, hope you experts can offer some advice.
Insert loaded cartridge with 6 (or fewer) discs, player cycles through all discs without stoping or loading any. I've tried other cartridges with same result.
Any clues as to what is going on here?
Thanks in advance,
Ron
rpludwig is offline
post #2 of 3 Old 02-20-2013, 08:38 AM
atom2's Avatar
I have the same problem,did you find any solution yet? Thanks
atom2 is offline
post #3 of 3 Old 04-01-2014, 03:43 PM
paperman35's Avatar
I have the same issue with the discs dont read and just move to next disc
any thoughts
paperman35 is offline
Reply CD Players & Dedicated Music Transports
