Does Denon 4802 support 96khz 24 bit audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-27-2011, 07:22 PM - Thread Starter
AlexA6404's Avatar
I am thinking of getting a squeezebox touch to hook up to a Denon 4802. Denon manual states that it support 96/24 DTS audio streams, but, does anyone know if it supports 2 ch 96/24 PCM ( as I think the SB touch outputs) also?
AlexA6404 is offline
post #2 of 4 Old 07-30-2011, 08:58 AM
JorgeLopez11's Avatar
Yes, the denon 4802R supports 96/24 PCM signals. It uses the Analog Devices AD-1864 DAC for all channels.
JorgeLopez11 is offline
post #3 of 4 Old 07-30-2011, 09:06 AM - Thread Starter
AlexA6404's Avatar
Thanks for the reply. I assume 8402. (non R version) does also, then.
post #4 of 4 Old 07-30-2011, 09:36 AM
Alex, I guess so. I took the data from 2003 Denon's AVR comparison chart.
You know, that kind of info one tend to collect now and then. At that time I was looking to an AVR and I fanally got the 3803 and this chart mentions the 4802R.
Nice AVR, BTW. Good luck!
Reply CD Players & Dedicated Music Transports
