Any suggestions for a 1/2 width good quality office CD player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-07-2011, 04:01 PM - Thread Starter
Kevin C Brown's Avatar
Liked: 27
1/2 width because I'd put it on top of my desktop PC, under my desk.
I've only somewhat looked around at this point so I haven't come across many brands or models yet.
Thanks !!
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #2 of 7 Old 09-08-2011, 07:34 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Why don't you want to use PC as player? Get a decent sound card, pair of active speakers and you are all set.
ap1 is offline
post #3 of 7 Old 09-08-2011, 11:10 AM - Thread Starter
Liked: 27
I use a PC now. I have 2 setups I rotate through: AMB y2 + CKKIII DAC/amp, and MF V-DAC + Schiit Valhalla. I want to compare those to a dedicated CD player (and/or with a DAC).
I have come across a few, but none are really floating my boat at this point for bang for the buck:
a bunch of Teacs
Pro-Ject CD Box (SE)
Cyrus
Cambridge Audio Sonata CD30
NuForce CDP-8 CD Player
DENON DCD-CX3 Micro CD/SACD Player
Audio Analogue Primo CD player (rev2.0)
post #4 of 7 Old 09-08-2011, 04:37 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Sorry, but I can't help audiophile itch. Computer with any mid level (semi-)pro audio card (either internal or external) is perfectly good for all types of stereo playback, including high-resolution records.
ap1 is offline
post #5 of 7 Old 09-21-2011, 02:09 AM
EDGroup's Avatar
i do believe parasound has something in the works for their Z series line. for something more upstream Musical Fidelity has a transport only cd player as well...
EDGroup is offline
post #6 of 7 Old 09-21-2011, 09:53 AM
Harrypt's Avatar
I'd go buy an old Meridian 508 used. Much better sound for about the same $$
Although, I don't know why you bother with a high quality cd player if you're going to run it through the computer.
Harrypt is offline
post #7 of 7 Old 09-22-2011, 06:52 AM
rocky1's Avatar
eastern electric mini-max
rocky1 is offline
Reply CD Players & Dedicated Music Transports
