Looking For A CD Recorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-30-2011, 12:10 PM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
Is this the right forum? Is so CD recorders are harder and harder to find. I have some vinly that I want to transfer to a digital format. My Phillips CD Recorder is a piece of junk and no longer records. If you know where I can find a decent machine let me know and thanks.
jbug is offline
post #2 of 6 Old 09-30-2011, 12:17 PM
TL5
TL5's Avatar
Quoted: 51 Post(s)
Liked: 35
I sent you a PM.
TL5 is online now
post #3 of 6 Old 09-30-2011, 01:46 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Why you do not want to use computer? Laptop plus external audio device from Emu or M-Audio is likely cheaper than standalone recorder. Required software (Audacity) is free.
ap1 is offline
post #4 of 6 Old 09-30-2011, 01:57 PM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I could do that. This is an area of audio that I have not put any time into and so the recommendations are turning the light on in my head. I've been more into the home theater side of consumer electronics.
jbug is offline
post #5 of 6 Old 10-03-2011, 06:25 AM
ClarkeBar's Avatar
Quoted: 25 Post(s)
Liked: 25
Hello,
My approach is the same as yours. Since 2000 or so I have been using twin drawer Harman Kardon recorders (CDR2, 20) but they are now both over ten years old and have gone flukey.
To replace them, I just bought a used (circa 2005) Sony W2000ES recorder from a great Ebay seller. Popped the top when it arrived and have to say the thing is built like a tank and works perfectly with excellent sound quality. Was leary of the 5 disc tray play side reputation in lesser Sony models but so far this unit is everything I hoped an ES Sony would be. Also thought about splurging for a Yamaha CDR HD1500 to act as bonus Music server but didn't want to spend the extra coin.
The more current Sony RCD-W500C (a less expensive version of the earlier ES design) seems to be the best option for buying new if you're looking for the convenience of internal recording, especially at higher speeds. I believe that unit is no longer manufactured but there seem to be some lying around NIB. There are a number of current single drawer units on the market if you only want to record from an external source at normal speed, such as for vinyl. They range in price from very reasonable (Teac) to quite expensive (Tascam), depending on brand. Along with Amazon and Ebay, check J&R, B&H Photo, etc. I believe even Wal-Mart sells Teac models.
ClarkeBar is offline
post #6 of 6 Old 10-03-2011, 07:56 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
Thanks. At least now I know what the options are.
jbug is offline
Reply CD Players & Dedicated Music Transports
