h/k DVD 48 for SACDs. anyone try it, and is analog ok? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-02-2011, 04:05 PM - Thread Starter
oohrah's Avatar
I have a h/k SACD that i purchased off of the Harman shop on ebay for under $50 earlier this year, and for the price, I like the DVD and CD quality with my set up (JBL ES90, 4 of them).
I'm looking to buy some SACDs and I know the DVD48 will play them, but I heard it will play them analog versus HDMI. Is there much of a difference here, and if i want to have a good SACD sound, should i consider a unit with HDMI?
Thanks for any advice for this forum newbie!
Cheers!
Douglas
oohrah is offline
post #2 of 2 Old 11-07-2011, 04:19 PM
quattroatl's Avatar
Liked: 34
I use the HK dvd48 for my sacd and dvd-a needs...works great!
quattroatl is offline
Reply CD Players & Dedicated Music Transports
