Sony PS-FL1 - Help! - Do I need a Phono preamp? - AVS Forum | Home Theater Discussions And Reviews
Old 10-04-2011, 02:25 PM - Thread Starter
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
Hi - I have run across this interesting turntable manufactured circa 1982. It has a cool slide out drawer which makes it great for mounting in a cabinet or rack, which is a main reason I'm thinking about picking it up.
I will want to connect this to my AVR which I believe has no dedicated Phono input. Will I need a Phono Preamp?
Description refers to this as a "Stereo" turntable, so I'm unsure.
Be gentle, I'm a noob at this vinyl stuff!
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
Old 10-04-2011, 05:32 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
You'll have to get a phono preamp. Years ago when the turntable was king all receivers had a phono section. Look to Audio Advisor, Music Direct or the Needle Doctor there's plenty of quality low cost phonos available in the $50-$100 range. Also check if your cart is in good shape and try to get a brush and some cleaning solution to keep you vinyl clean. Records need some care to get the most out of them.
Class A is offline
Old 10-04-2011, 07:58 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
If it's like the FL7, it's a belt drive and the rubber will probly need replacement. There is another model in the serie that has direct-select track buttons, apparently the sensor reads the shinny groves between the tracks and with a push of a button, it can be told to jump to track x.
MrBobb is offline
