ADS/Braun P2 and general record player questions - AVS Forum | Home Theater Discussions And Reviews
Old 10-11-2011, 06:44 PM - Thread Starter
everybest's Avatar
I got a new cartridge, thanks to some help on my other thread, but being my first record player, I have some questions on operation and other stuff, if anybody could help me out (it didn't come with a manual)
1) What are these for?
a.
b.
c. A window/display on the front. Buncha dots, not sure what it means.
d. What am I turning on and off?
2) I can adjust where the cartridge sits on the rod. Is there an optimal placement or is it trial and error or does it not matter?
(edit: I found a stylus alignment protractor hidden in the shure cartridge box with no usage instructions and doesn't make any sense to me.)
3) The volume on the record player is really low, I have to turn the receiver almost to max. Is there something I can change physically to alter the volume?
4) A few pieces snapped off while being shipped, most of which is no big deal, I'll just glue them back. But I found this piece and I can't figure out where it goes, it might not even be a part of it.
5) The plate is scratching against something underneath, I can hear it once every revolution and it's pretty loud but I can't figure out what it is. Is this a common problem and is there an easy way of figuring out what it is?
everybest is offline
Old 10-12-2011, 03:30 PM
Roseval's Avatar
Quoted: 37 Post(s)
Liked: 25
a- lift the arm
b- anti skating
c- strobe, one band should stand still when turning at proper speed
3- do you use a phono in? You need a phono stage (more amplification/ RIAA correction). Sound like you are using a conventional line in.
Maybe this is of use:
http://www.vinylengine.com/articles.shtml
http://wegavision.pytalhost.com/BraunP2s/
Roseval is offline
Old 10-13-2011, 07:58 PM - Thread Starter
everybest's Avatar
Originally Posted by Roseval View Post
a- lift the arm
Thanks, doesn't seem to be doing anything, I guess it's probably broken.
Cool, so I use the pitch dial until the one band stands still?
Is this the same as an amplifier? I would assume there's a component in the braun atelier series to make everything work together. I already have a receiver (R4), just that the record player sound coming in is much softer than from every other source. Do I need an additional amplifier solely for the turntable?
Old 10-22-2011, 03:29 PM
Roseval's Avatar
Quoted: 37 Post(s)
Liked: 25
Check if the receiver has an input explicitly labeled as phone
Roseval is offline
Old 11-24-2011, 12:35 PM
merkin77's Avatar
The thumbscrew holds the head to the arm (the screw faces up and comes in from the bottom)
sounds like this unit is a bit rough
merkin77 is offline
