getting into high quality music need cd player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-11-2011, 03:40 AM - Thread Starter
extrafuzzyllama's Avatar
Quoted: 25 Post(s)
hi all
i am getting into better sounding music over my mp3s
i am interested in a good cd player but is it worth it?
i have plenty of cds and have most on flac i ripped myself
i am not sure which cd player for under $200 that will be good
any advice would be great
thanks in advance
extrafuzzyllama is offline
post #2 of 7 Old 11-11-2011, 04:51 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Originally Posted by extrafuzzyllama View Post
hi all
thanks in advance
There are no standalone CD players worth mentioning under $200. It is niche market now, so price is high. For Flac, get Squezeebox Touch (I saw it offered for $230 recently), it has good DAC inside (comparable to any sub $1000 player). If you still want to play physical CDs, do it on your home theater system, using DVD/BD player as a transport. DACs inside most mid-range receivers are sufficient, unless you have multi-thousand dollars speakers. But then you likely won't limit your budget to humble $200.
ap1 is offline
post #3 of 7 Old 11-11-2011, 10:32 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
Exactly. Almost the same as my system.
jdcrox is offline
post #4 of 7 Old 11-11-2011, 10:53 AM - Thread Starter
Quoted: 25 Post(s)
in that case i might save up for a oppo 93
post #5 of 7 Old 11-11-2011, 08:03 PM
someoledude's Avatar
Quoted: 14 Post(s)
Great choice!
someoledude is offline
post #6 of 7 Old 11-11-2011, 08:19 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
I've had great luck over the years buying used (knock on wood) and recently picked up a used Oppo 83 for about 3 bills.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #7 of 7 Old 11-11-2011, 09:57 PM
postrokfan's Avatar
Quoted: 592 Post(s)
Liked: 3522
The Oppo 93 is a great choice. It's pretty good for analog audio (if that is your intent) but obviously not as good as the Oppo 95.
Living Room: B&W 804D2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
Reply CD Players & Dedicated Music Transports
