Phono preamplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-12-2011, 01:07 PM - Thread Starter
cooldude1606's Avatar
My Denon receiver does not have a phono input on it, so I need a special preamp for a turntable to work properly with it, any suggestions on a good preamp?
cooldude1606 is offline
post #2 of 7 Old 11-12-2011, 01:27 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
How much do you want to spend? $50 or so will get you a decent one at www.phonopreamps.com. $150 covers the Parasound Zphono.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 7 Old 11-12-2011, 01:47 PM - Thread Starter
thankyou, this helps me alot.
post #4 of 7 Old 11-12-2011, 01:59 PM
Leo King's Avatar
Also, please search Amazon for the phono preamps.
Leo King is offline
post #5 of 7 Old 11-12-2011, 04:47 PM
gillcup's Avatar
Quoted: 95 Post(s)
Liked: 4053
I have a Cambridge Audio 640P and am very happy with it. I had a Parasound zphono and it died after 6 months (of course YMMV). The 640 has been running like a champ for years now.
Mark
gillcup is offline
post #6 of 7 Old 11-13-2011, 07:35 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
CA 640P is a very good preamp, unless you want to use non-standard load (required for some cartridges). In that case you need preamp with variable cartridge load, which are usually much more expensive.
ap1 is offline
post #7 of 7 Old 11-20-2011, 09:07 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
The Musical Fidelity phono preamp, for $150, is superb; comparable performance to much more expensive units.
It sounds almost as good as my Audio Research PH-5 ($2000).
commsysman is offline
Reply CD Players & Dedicated Music Transports
