Looking for a HIGHER END 5 disc cd player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-21-2011, 10:48 AM - Thread Starter
sillycyberfunguy's Avatar
I see a Marantz 5 disc changer (see below) but i was wondering if there are better multi cd players out there ...NAD, Arcam etc.
Here is the Marantz:
http://www.musicdirect.com/p-1889-ma...d-changer.aspx
Certified Grade "A" Vidiot through and through - Gaming daily on NAD M25, Marantz AV8801, Diapson Adamantes III (L/R) , PSB synchony one(CENTER), POLK LSi FX (sides) Polk LSi 9 (rears) - 7.1 for life!
SEE SETUP BELOW
http://www.flickr.com/photos/99629181@N06/
sillycyberfunguy is offline
post #2 of 3 Old 11-21-2011, 08:08 PM
Brian B's Avatar
Quoted: 235 Post(s)
Liked: 102
Nope. You would have to look at a music server like the Olive Media (in the other thread).
B.
Brian B is offline
post #3 of 3 Old 11-30-2011, 10:15 AM
centurymantra's Avatar
Generally speaking, a thread that poses a question like this tends to devolve into circular flame wars as there is a large and vocal contingency who represent the dominant paradigm on this site asserting that all CD players sound the same, so I would suggest you don't go there... On the other hand...if you are not of this camp and do want to go there, I would suggest posting at www.audiogon.com with the other believers.
If you want to ask about which high end CD players are simply better built and more durable, you might able to keep things civil. That being said, there aren't too many CD changers being made nowadays. I think Arcam may still have one out there, and I know I have seen some McIntosh CD changers which I imagine are quite nice. There is always the used market, but that could be a bit dicey. I remember some nice players from Anthem and California Audio Labs. I think that Cal Audio one is still fairly sought after, if you can find it. I do own that Marantz and it has been a good player for me. I like it, although it has a tendency to randomly skip a disc on occasion. You can find Marantz refurbs for cheap over at Accessories4less.com
Cheers!
centurymantra is offline
Reply CD Players & Dedicated Music Transports
