Vacuum Tube Audio Components - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-08-2011, 08:41 AM - Thread Starter
NetGod's Avatar
I found a high quality CD player, tuner, dedicated i-POD input and tube power amplifier all in one chassis that I would like to buy, but am concerned with the the life span of the tubes and ease of servicing such a unit should it become disabled.
Any advice and opinions would be greatly appreciated.
2 Hometheaters
7 HDTV's 32" to 60"
2 Desktop gaming computers
4 Gaming consoles (1 XB, 2 XB360, 1 XB1, and 1 PS4)
80+ total video games
2 iTouch & 1 iPad Air
NetGod is offline
post #2 of 10 Old 12-08-2011, 09:14 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
If you mean it's some kind of all together piece, like when you see TV's that incorporate a DVD player, the best thing would be to contact the vendor and see if you can get a handle on how repairs, especially post-warranty ones are handled.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #3 of 10 Old 12-08-2011, 09:40 AM - Thread Starter
NetGod's Avatar
I did contact the vendor. He says the tubes only last 3-5 year.
Does that sound like the correct life span of a vacuum tube?
2 Hometheaters
7 HDTV's 32" to 60"
NetGod is offline
post #4 of 10 Old 12-08-2011, 11:50 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Doesn't sound bad. When they die, so long as you don't go artsy fartsy with replacements you should be able to source them pretty easily. Maybe your local Guitar Center.
Chu Gai is offline
post #5 of 10 Old 12-08-2011, 12:51 PM
Harrypt's Avatar
Nobody with tube knowledge and experience can answer and give any credible advice if you don't tell what the piece is so it is known what type of tube and how it is used in the circuit.
Harrypt is offline
post #6 of 10 Old 12-08-2011, 01:08 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 3974
Raysonic ML-6? http://www.raysonicaudio.com/product_details.php?ID=22
How many tube CD player/tuner/ipod dock/integrated amp products can there be?
Replacing tubes should not be a problem at all in this piece.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #7 of 10 Old 12-08-2011, 02:23 PM - Thread Starter
NetGod's Avatar
larry
Actually the piece I had in mind was a Shanling, but have very quickly learned Shanling is not a desirable brand. So yes, Raysonic is one brand I'm looking at. Alternatively, I'm also very seriously considering a dedicated tube CD player such as the Raysonic CD-138.
2 Hometheaters
7 HDTV's 32" to 60"
NetGod is offline
post #8 of 10 Old 12-09-2011, 05:15 AM
Moderator
Moderator
Quoted: 286 Post(s)
Liked: 3974
There's a lot of people who use tubes, myself included, and are very happy. Power tubes in an output stage of an amplifier tend to have shorter lives than "driver" type tubes. Tube lifetimes can be in the thousands of hours depending on type and application. There's so many variables that you can't make across the board type statements or comparisons.
larry
post #9 of 10 Old 12-12-2011, 03:28 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
3 - 4 years is a right lifespan for tube. They last between 1000 and 3000 hours. But I do not think that this is a smart idea to mix tubes and solid state digital electronics in one package. Tubes produce a lot of heat and require high voltage powers sources. Both of them are not good environment for high speed solid state circuits needed for CD player and iPod connector.
ap1 is offline
post #10 of 10 Old 12-12-2011, 05:53 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
I have used tubes for over 40 years and like the sound they produce, but the high-power tubes currently available are very unreliable and very expensive. When Stereophile and other magazines review tube power amplifiers, they almost never get through the review process without a tube failing; and these tubes are usually the best available.
I have an Audio Research preamp that has tubes, and the sound quality is superb, but I have sworn off of tube power amplifiers for good. They are too expensive to maintain and repair; very unreliable. I get about 1000 hours out of my preamp tubes; you are lucky to get 300 hours out of a $60 KT88 power tube these days; anyone who says different is full of it! I have been there and done that.
I cannot conceive of any possible reason to have a tube in a CD player; that is BS; silly posturing.
Having a CD player in the same chassis as a power amplifier is stupid, because the power amplifier power supply circuitry cannot be isolated well enough from the CD player circuits. That is stupid engineering practice. A CD player should be a separate unit. Besides, servicing would be a big pain with an all-in-one unit.
I would recommend a good solid-state integrated amplifier and a good CD player. Most integrated amplifiers have a front-panel jack for an Ipod connection now.
The Cambridge Audio 650A integrated amplifier and 650C CD player are very good, at about $700 each.
You didn't give any clue what you intend to spend. When you say "high-quality", that leads me to believe you are in for at least $2000 or more; pretty hard to get anything for less that could be called high-quality.
[/quote]
commsysman is offline
Reply CD Players & Dedicated Music Transports
