Which CD Player should I keep which one should go? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-09-2011, 09:02 AM - Thread Starter
GuyFrom1970's Avatar
I have an Onkyo DX-1400 and an older Teac Single Disc CD Player Model # PD-80. Which CD Player is better? Thank You for your help.
GuyFrom1970 is offline
post #2 of 7 Old 12-09-2011, 09:19 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Lacking any other information, I'd say keep the one that's been used less. It'll probably last longer.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 7 Old 12-11-2011, 09:10 AM - Thread Starter
I am not able to provide Specs on these CD Players What other information do you guys need?
post #4 of 7 Old 12-11-2011, 09:39 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
None. Specs would just tell you that they probably sound identical (which they probably do, if they're still in good working order). Hence my reply above.
mcnarus is offline
post #5 of 7 Old 12-11-2011, 09:41 AM
WilliamZX11's Avatar
Quoted: 25 Post(s)
None really. They are both very old models, if I were you I would keep both, so you will have a spare if the one you are using fails. Not like you could sell one for hundreds of dollars or anything.
WilliamZX11 is offline
post #6 of 7 Old 12-11-2011, 12:08 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Which ever one, after level matching the output, you prefer.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #7 of 7 Old 12-22-2011, 09:48 AM
BOSTON-HD's Avatar
Quoted: 57 Post(s)
I still own my Onkyo DX-1400 that's in my office (not my main set up) & it's paired with a Nakamichi RE-10 receiver & some AR speakers. Anyway...The Onkyo still "chugs" along & it's still sounds very nice IMHO. It purchased that new back in 1990-91 I recall. Built like a tank!
BOSTON-HD is offline
Reply CD Players & Dedicated Music Transports
