Help - I want to buy a turn table for my son - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-18-2011, 01:22 AM - Thread Starter
gkornfeld's Avatar
My son is going vinyl. I want to get him a turn table that is decent quality and maybe has a USB interface; though this is not a must. I have an old receiver for him that has a phono input too. Lost of options on ebay; but I'm not sure what is a good price or good quality. so I'm thinking of going with a new version. I want to spend between $200 to $300. Can I get some help and a good site to purchase. Thanks
gkornfeld is offline
post #2 of 12 Old 12-18-2011, 05:04 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Check out the Needle Doctor they have a very nice Audio-Technica LP-120 USB TT for 299.95. It has a built in phono but you can switch it off if your phono in your receiver is better. Also it's a direct drive w/3 speeds 45/33/78 so he can play any vinyl format on the TT.
Class A is offline
post #3 of 12 Old 12-18-2011, 07:59 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
The Audio-Technica 120 is a good choice. See this review.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 12 Old 12-18-2011, 08:57 AM - Thread Starter
gkornfeld's Avatar
Thanks... The AT-LP120 is $219 on amazon but the LP240 is $299. WOuld you upgrade for the extra $80. What do you get for the aded dollars. Thanks
post #5 of 12 Old 12-18-2011, 09:36 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
The 240 is a better table, aimed more at the audiophile than the DJ. Better specs overall, including speed stability and noise. OTOH, I don't think the 240 comes with a cartridge, which means you'd have to buy and install that, as well. The 120 comes with a cartridge (though not a particularly good one—an early upgrade would be a good idea).
mcnarus is offline
post #6 of 12 Old 12-18-2011, 01:55 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
If you order the TT see if they'll add on a better cartridge for an extra charge. A Shure 97xE would be a nice inexpensive add on. If your not very skilled at putting on a cart yourself this would be a safe way for installing one.
Class A is offline
post #7 of 12 Old 12-22-2011, 11:44 AM
dannybenz's Avatar
Quoted: 13 Post(s)
I have the atlp120usb with the m97xe. Im using the onboard phono stge to a receiver running in source direct mode. I dont know if its just me but it doesnt sound too great. I am using the reccomended tracking force by shure and the tonearm was properly balanced. What can i do to improve the sound?
dannybenz is offline
post #8 of 12 Old 12-22-2011, 04:34 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I would start with cartridge. Get AT440, you may like it better. Then phono preamp. I recommend CA 540. If still do not like it after that, get ready to spend $1000 for a new table.
ap1 is offline
post #9 of 12 Old 12-22-2011, 04:52 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
You know, I've often wondered if the M97 is such a good match for that table. IIRC, it's a pretty high compliance cartridge, by current standards, and that S-shaped arm may be higher mass, as well. (Spec sheets are woefully incomplete.) Not an ideal combo.
mcnarus is offline
post #10 of 12 Old 12-23-2011, 09:15 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
The M97XE is a very good sounding cartridge. It's possible the AT's onboard phono stage is the problem. Does your receiver have a phono preamp? You might consider getting a receiver with a phono preamp, or else buying a good external phono preamp.
seatacboy is offline
post #11 of 12 Old 01-16-2012, 02:38 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Try the MUSIC HALL - USB-1. Has USB port and mounted AT cartridge. About $250.
http://www.musicdirect.com/p-9826-mu...turntable.aspx
domino92024 is offline
post #12 of 12 Old 01-29-2013, 03:53 PM
davethestalker's Avatar
Quoted: 49 Post(s)
I'm in the researching stage for buying a table. The LP120 is going for about $225 on Amazon. The LP240 got axed and replaced with the LP1240. Which added features desirable by jocks. Pitch adjustment, dual start/stop buttons, upgrades preamp, still beautiful piano black. Sporting a $419 price tag and no cart.
The deal at DJ Gear with the LP120 + an upgraded cart is intriguing. I'd like to get an LP240 with a decent cart for not much over $300.
A lot of people are saying that Shure cart sounds flat, it does not like heavy tone arms. The AT 120E looks like a great cart for $100. But it's very fragile.
The search goes on.
Kuro owner from Cleveland Plasma.
Pro-Ject Debut Carbon w/Acryl-It platter, Phono Box S
DENON AVR-X7200wa, Paradigm Monitor 90p v1
Def Tech system: CLR2300 SM450 surrounds, BP1.2x rear surrounds, Polk PSW-505
Previous AVRs: AVR-4520ci, RX-A710, RXV-2200
Instagram: DaveTheStalker, PSN ID: DaveTheStalker GT fan since day 1.
davethestalker is offline
Reply CD Players & Dedicated Music Transports
