Technics SLB-2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-20-2011, 02:51 PM - Thread Starter
sdlehman's Avatar
I have a Technics SLB-2 turntable I received as a gift many years ago. Are there any improvements I can make other than replacing the cartridge? For example I am wondering if the output leads were replaced with something of higher quality would that be an improvement worth the trouble?
Stace
sdlehman is offline
post #2 of 3 Old 12-20-2011, 03:30 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Not unless they're broken.
Probably wouldn't hurt to replace the belt.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 3 Old 12-21-2011, 05:27 AM - Thread Starter
sdlehman's Avatar
Thanks for the reply. The belt is pretty old. Not the orignial but probably 15 years old.
Stace
sdlehman is offline
Reply CD Players & Dedicated Music Transports
