Help? Easiest way to a higher quality sound in my setup. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-04-2012, 10:18 PM - Thread Starter
Mpls_Ben's Avatar
I need some purchasing advice. I'm on way way to a good 2.1 music system, but I'd like some advice on what I can do to push it into "Great" territory. I'm 75% music 25% movies and games. After reading tons of AVS and head-fi posts I am spinning. I have about 450 dollars i can drop to add something to my system and I'm just so confused. I would greatly appreciate your expertise. Thank you,
My gear:
ps3 > new but cheap Yamaha rx-v367 receiver > Paradigm Mini Monitors and delivering at the end of the month- Outlaw LFM-1 Ex sub!:
separate room: ipod classic 80gb and imac / er4p headphones
Gear I'm considering after reading post after post:
Apple TV - I've heard that the sound quality isn't great because it downsamples but is it really that noticable? only 100 bucks.
Squeezebox Touch - Better sound if i go to FLAC / worse interface?
Dedicated CD Player - H/K HD990, BDP-93, CA 650c
Schiit Bifrost, or another DAC?- I've heard that maybe i don't need a DAC because my reciever/ ps3 might handle it? this doesn't make sense to me because they are both cheaper than the bifrost or another recommended DAC.
Mpls_Ben is offline
post #2 of 14 Old 02-05-2012, 07:23 AM
WilliamZX11's Avatar
Quoted: 23 Post(s)
Out of those choices I'd go with the Squeezbox. Nothing more convenient than having all your music available from a single source.
Why doesn't it make sense? Large companies can make thing a lot cheaper due to economies of scale. If Sony or Yamaha were to build that dac it wouldn't be anywhere near $350, probably closer to $50, there's really not much to it. The case probably cost as much as the electronics.
WilliamZX11 is offline
post #3 of 14 Old 02-05-2012, 07:35 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 371
Unless you've got something higher resolution than CDS, it does not downsample.
Nope. Same sound quality as Apple Lossless (or WAV or AIFF) on the Apple TV. Interface is a matter of taste.
Way, way down the priority list. Little to no bang for the buck.
Ditto.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 14 Old 02-05-2012, 09:20 AM - Thread Starter
Mpls_Ben's Avatar
Thanks for the feedback William/mcnarus. Interesting note about the DAC's since it seems to be an obsession on these forums.
I bought the ps3 thinking it would solve many of my problems:
wireless music from my imac: I feel like I'm losing a lot on sound quality from ps3.
bluray, sacd, dvd, cd player: I now realize I only need cd and dvd. access to bluray and sacd just isn't there for me.
Now I'm starting to think it was a dumb decision.
Just looked through craigslist at a mac mini 2009 w/ 8gb ram for $400. Could be a good option to start the music server i feel that i need. i have an ipad so it could be more useful than the squeezebox touch.
From previous posts I was under the impression that appletv was not as good as cd quality. I've read that most audiophiles in this case try to go Pure Music > Mac Mini > spdif- DAC > reciever. If an appletv is really that good then it's well worth the $300 I'd save. Thoughts?
Mpls_Ben is offline
post #5 of 14 Old 02-05-2012, 06:19 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 175
The two biggest things I would be looking into if I were you would be, a) new speakers, and b) a new receiver. That would make a huge difference in your system. Much more than any of those other things you listed. You can purchase a pair of Ascend Acoustics Sierra-1 bookshelves for around $600 to $700 used. That would be a night and day difference, compared to what you have now. Next, I would be looking into a better receiver.
Martycool007 is offline
post #6 of 14 Old 02-05-2012, 07:02 PM
Quoted: 23 Post(s)
How does he do that with $450?
post #7 of 14 Old 02-06-2012, 05:59 AM
Quoted: 280 Post(s)
Liked: 175
He doesn't. He would need to save up some more cash.
post #8 of 14 Old 02-06-2012, 06:06 AM
Moderator
PooperScooper's Avatar
Quoted: 192 Post(s)
Liked: 2726
Before spending more money you should probably maximize what you have now, or will have once the sub comes in. Speaker placement and room acoustics offer the biggest possible change in sound. Properly integrating your sub into room and your 2 main speakers should be done before buying new equipment - except maybe a sound meter.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #9 of 14 Old 02-06-2012, 10:20 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 143
The first thing to do is EASILY speakers. Period.
Having heard the TriTrix, well they are going to be hard to beat for less than $600 commercially.
$259 for the pair and you assemble. You could vinyl veneer them:
Black Ash
Cherry
Oak
etc....
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #10 of 14 Old 02-07-2012, 05:40 AM - Thread Starter
Mpls_Ben's Avatar
I guess I really wasn't prepared to hear that my speakers aren't worth getting a nicer player/DAC (if ever necessary)/amp. My next purchase would likely be a new pair of speakers then. I was always of the mind that great speakers can make a huge difference, but not if you have poor source/equipment paired with it. Could you elaborate on the sound meter? Thanks everyone for your input.
Mpls_Ben is offline
post #11 of 14 Old 02-07-2012, 08:30 AM
Dr_Mark's Avatar
Quoted: 128 Post(s)
Liked: 179
I live in Minneapolis too and several of us are working on that very issue. I don't like the Apple TV, nor the TVIX box. The sound and picture quality are not that good compared to other solutions. The Apply TV sounds and looks like a soda left open for a week, dull and flat. The TVIX is better but not there.
I am using a Mac Mini linked to a server with video and audio files. The software I am using is XBMC, will do it all music and video. Looks great and sounds great too, will to 24/96 files. A couple of people are working on PC solutions and they sound good.
Life is enjoyable with good quality
Dr_Mark is offline
post #12 of 14 Old 02-07-2012, 08:33 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
Ohhhh... the Rx-367 doesn't have YPAO. Good catch.
Yeah I'd track down a better receiver.
The brick-and-mortar stores around me are clearing out last years models.
You should be able to get an 867 or 1067 for $450 if you catch an online sale.
defdog99 is offline
post #13 of 14 Old 02-07-2012, 04:14 PM - Thread Starter
Mpls_Ben's Avatar
The Outlaw sub isn't supposed to ship until the 27th. I'm seriously considering cancelling the order and saving for some good tower speakers and a better reciever.
Mpls_Ben is offline
post #14 of 14 Old 02-08-2012, 04:55 AM
mpenton's Avatar
Use what you have, YPAO is pretty useless for sub-crawling two channel music. For an increase in convenience the Apple TV will let you access the music you have on the iMac in iTunes using the iPad as a remote. Sonically I have problems telling the difference between that and the Mac Mini I use as an HTPC, perhaps it's because I have both wired to the home network instead of going wireless. The hardware on the Mini will do 24/96 but AFAIK XBMC won't play those files properly (I'm not running the betas just the last general release of 10). Spend your money on extra storage space & music until you have identified the best upgrade for you. Borrow a friends amp, speakers, CD and see if that gives you the boost, otherwise it's going to be a crapshoot.
mpenton is offline
Reply CD Players & Dedicated Music Transports
