Pionerr DV-48AV Vs Oppo DV-980H for Audio Only (SACD/DVDA/HDCD) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-24-2012, 09:31 AM - Thread Starter
JoeMG's Avatar
Looking for a SACD/DVDA player that outputs DSD 5.1 over HDMI.
Also not looking to spend much money.
From everything I've seen, these 2 look like my best options. Here are the pros and cons i've come up with:
Oppo:
Plays HDCD (which I don't currently own)
Pioneer:
Slightly better specs
am i missing anything? I'm leaning towards the Pioneer because the specs are better and it looks like it was probably a higher end unit in its day. HDCD is a cool feature, and i would probably find some HDCDs, but not worth a lesser player.
JoeMG is offline
post #2 of 9 Old 02-24-2012, 10:22 AM
WilliamZX11's Avatar
Quoted: 25 Post(s)
I've got the DV-48AV, it plays everything I've thrown at it. There won't be any difference between the two over HDMI anyways.
The DV-48AV was available on closeout for $99 for a very long time. That's what I paid for mine, so I don't know how "high end" it is. I wouldn't pay more than $50 or $60 for a used one, and that would have to be mint.
If you can find one, the DV-49AV that replaced it was almost identical.
WilliamZX11 is offline
post #3 of 9 Old 02-24-2012, 02:39 PM - Thread Starter
JoeMG's Avatar
That's a good point about the HDMI. Is there anything else that would make one better than the other?
JoeMG is offline
post #4 of 9 Old 02-24-2012, 02:48 PM - Thread Starter
JoeMG's Avatar
also... the DV-49AV also did 5.1 DSD over HDMI? I'll keep my eyes out for that.
JoeMG is offline
post #5 of 9 Old 02-24-2012, 07:17 PM
Quoted: 25 Post(s)
They really aren't much different. Both use a Mediatek chipset for DVD up-conversion, and play most of the same formats.
Yes, they both did.
post #6 of 9 Old 04-23-2012, 11:11 AM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
I don't think the Oppo DV-980H can output dsd over hdmi since it doesn't have hdmi 1.3. I believe the Oppo converts to pcm and the outputs via hdmi.
I used to have the Oppo 981 and could not get dsd. When I switched to a Sony BR player, I was able to send a dsd stream to my receiver.
audit13 is offline
post #7 of 9 Old 04-23-2012, 01:42 PM
Ovation's Avatar
Quoted: 104 Post(s)
Liked: 71
Only needs HDMI 1.2 for SACD playback. My Cambridge Audio DVD89 is a 980H clone (essentially) and it sends DSD via HDMI to my receiver.
Ovation is offline
post #8 of 9 Old 04-23-2012, 02:25 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
I didn't know that 1.2 is all you need. I no longer have my 981 so I can't test the dsd function. Maybe I didn't have it set up properly.
audit13 is offline
post #9 of 9 Old 04-27-2012, 09:31 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
According to OPPO's comparison chart the 981 (and 983) didn't do DSD via HDMI. The 980 did.
I have an Elite 48 (and a 58) and it's a fine player. For audio quality I doubt you would notice a difference between either one but the 48 shows a better S/N ratio (115 vs. >100).
gene c353 is offline
Reply CD Players & Dedicated Music Transports
