Technics SL-MC400 cd changer adjustment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2012, 04:58 AM - Thread Starter
garbhead's Avatar
Have a Technics SL-MC400 110+1 cd changer that doesn't go to the proper number when chosen(1 number off). Is there some way of adjusting this to "index" correctly...I am in process of replacing drive belt for carrier unit.
garbhead is offline
post #2 of 2 Old 10-25-2012, 07:40 PM
Cain Dogg's Avatar
I have had the same problem with mine for some time, then within the last few months the drive mechanism started malfunctioning all together. Preliminary analysis suggests the drive belt is worn out. Did you fix your problem by replacing the belt?
Cain Dogg is offline
Reply CD Players & Dedicated Music Transports
