Phono Preamp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-05-2012, 03:39 PM - Thread Starter
topshotta's Avatar
I just picked up a Denon AVR-1912 receiver, which of course doesn't have phono input. Can anyone recommend a good phono pre-amp to use with my 20 something old Technics SL-1200? I listen to music from this about 10% of the time, so I don't want to spend a lot of money - just something that will get the job done without sacrificing too much.
topshotta is offline
post #2 of 10 Old 04-05-2012, 04:19 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
For about $50, you can pick up a decent one at www.phonoreamps.com. If you want to spend more, consider the Parasound Zphono at $150 or so.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 10 Old 04-06-2012, 08:29 AM
FreakyFraser's Avatar
I have a 750 from phonopreamps and find it's pretty good for the money spent. I'm eager to consolidate all my sources into one Preamp though (Parasound 2100)
"There can be only one!"
- The Highlander
FreakyFraser is offline
post #4 of 10 Old 04-10-2012, 09:07 AM
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
I purchased the TCC TC-750 (like the one pictured on www.phonopreamps.com) to pair with my 80's new to me Sony turntable, going into a Yamaha AVR with no phono section.
I actually scored mine off EBay, so it was even a bit cheaper. I don't listen to vinyl that often, and my TT is not high-end, so I wanted something reasonable.
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
post #5 of 10 Old 04-17-2012, 07:41 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
I highly recommend the Musical Fidelity V-LPS. It is around $140, and sounds as good as some costing much much more.
The Cambridge 551P is a bit cheaper, from Needle Doctor. They also have some for under $100.
commsysman is offline
post #6 of 10 Old 04-19-2012, 06:21 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Get Cambridge Audio 640P, or 540P if you do not plan using MC carts.
ap1 is offline
post #7 of 10 Old 04-19-2012, 06:37 AM
davidflas's Avatar
I have been very happy with my Musical Fidelity V-LPS mkII that I use with my Rega RP-1 and Aragon 18k mkII preamp.
davidflas is offline
post #8 of 10 Old 05-20-2012, 02:48 PM
jon5's Avatar
I have a NAD PP1 that sounds very good through Denon 3805. Nice warm sound! You can find them fairly cheap too.
jon5 is offline
post #9 of 10 Old 07-19-2012, 09:52 PM
goodtimes's Avatar
I heard a Yaqin tube phono stage that sounded excellent.........then again i have only used built in phono stages on new and vintage receivers. I still want one and they are about $125.00 on ebay i believe. Any one have any other suggestions on tube phono preamps???
"goodtimes"
goodtimes is offline
post #10 of 10 Old 07-20-2012, 12:45 AM
acebreathe's Avatar
Quoted: 175 Post(s)
Liked: 99
Check out Bellari, they make fairly affordable tube phono preamps.
acebreathe is offline
Reply CD Players & Dedicated Music Transports
