Turntable advice for a beginner audiophile? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 04-17-2012, 10:19 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Yet, there are good belt driven TTs, designed with good isolation and "inertial" stabilized, I wouldn't discount a TT just because it has a belt, unless you are a DJ.
Nor would I. They're really just two ways to solve a problem. Implemented well, either can work.
But IF your primary concern is speed accuracy/constancy, AND IF your budget is in the hundreds rather than the thousands, THEN you will almost surely be happier with a DD unit.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #32 of 34 Old 04-17-2012, 11:09 AM - Thread Starter
mediamale.tn's Avatar
I wouldn't mind a belt drive table as long as the wow and flutter were not noticeable.
But I do find the setup process (counterweight, stylus pressure settings, etc.) somewhat intimidating. Are any of the preset models even worth considering (Marantz TT42, Thorens TD158 etc.)? They come all set up, just plug and play. (I would imagine that with those, one is stuck with the stock cartridge though).
mediamale.tn is offline
post #33 of 34 Old 04-17-2012, 11:30 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
The only way to know for sure is to try one.
These are generally set up properly (though it never hurts to check). The only thing you have to do is set the tracking force and maybe the antiskate, but those are really trivial.
If you want the plug and play option, yes. Or, as I said earlier, most dealers (including online ones) will mount a different cartridge for you. Again, they'll probably do a good job, but it never hurts to check.
mcnarus is offline
post #34 of 34 Old 04-17-2012, 11:33 AM - Thread Starter
Thanks for you help... I think a purchase is in my very near future
Reply CD Players & Dedicated Music Transports
