Looking for a Turntable For Around 1,000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-23-2012, 11:12 AM - Thread Starter
jconsolmagno's Avatar
Any suggestions? Been heavily considering the Music Hall 5.1, going to pull the trigger late this week, but doing as much research as I can beforehand. Thanks!
jconsolmagno is offline
post #2 of 10 Old 04-23-2012, 01:07 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Also consider the Pro-Ject RM-5 SE, or the REGA - RP3.
domino92024 is offline
post #3 of 10 Old 04-23-2012, 09:08 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Amazon has Technics SL1200MK5 for exactly your price. Get classic while you still can.
ap1 is offline
post #4 of 10 Old 04-24-2012, 01:26 PM - Thread Starter
Have always heard good things about this table but recently there hasn't been much buzz about it. Figured that the other companies I was researching had closed the gap at least by now from when I made my last purchase years ago since recent reviews don't mention the technics anymore.
post #5 of 10 Old 04-24-2012, 02:08 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
That's because it's no longer made. That's why the price is as high as it is. (Less than a decade ago you could pick one up for $400 or so.) All the little belt-drive companies are not closing any gaps; they are tinkering at the margins.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #6 of 10 Old 04-27-2012, 09:33 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 523
I have the Music Hall MMF-7 at one house and the 2.2 at the other. I personally think the difference between the 2.2 and the 5.1 is insignificant. The really significant improvements only come with the 7.1.
I would suggest that you get the 2.2 and spend $400 on a Benz Silver cartridge for it. That is what I did and the sound quality is excellent.
commsysman is offline
post #7 of 10 Old 05-01-2012, 06:12 AM - Thread Starter
Thanks to your advice, went with a Pro ject 5.1 that was a in-store demo unit for $300 off. Ordered the Magnespan MMG for the 60 day trial as well.
post #8 of 10 Old 05-01-2012, 07:07 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
If it was used as demo, than stylus or whole cartridge replacement should be your first step. You never know how many hours it was running.
ap1 is offline
post #9 of 10 Old 06-08-2012, 04:39 AM
RAART's Avatar
You should get the Marantz...
RAART is offline
post #10 of 10 Old 06-10-2012, 02:50 PM
GlassWolf's Avatar
Good choice. I actually just bought an RM 1.3 Genie for the amount you saved on your demo 5.1 haha If you're looking for a replacement cart, I'd recommend the Ortofon OM40 Super in MM, or the Dynavector 10X5 (the one I personally use) in high-output MC.
Also start looking around for a good phono stage, and consider buying the pro-ject speedbox II. World of difference.
-GlassWolf
My Home Cinema
GlassWolf is offline
Reply CD Players & Dedicated Music Transports
