Best transport for a Rega DAC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-07-2012, 07:54 AM - Thread Starter
nbaptista's Avatar
Hi,
I have a Rega dac and I´m looking for a transport...should I look for a cd player and use the coaxial out? Which cd players are good transports?Cambridge 651 C, Marantz?
nbaptista is offline
post #2 of 13 Old 05-12-2012, 07:33 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Originally Posted by nbaptista View Post
Hi,
Good idea.
I'm under the impression that this Rega is designed to have lots of built-in jitter rejection, so it should sound great with just about anything with a digital output.
arnyk is offline
post #3 of 13 Old 05-12-2012, 09:23 AM - Thread Starter
nbaptista's Avatar
Even an entry level Cambridge 340 C ?
post #4 of 13 Old 05-12-2012, 09:32 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
If you want to spend that much.
Seriously, the DAC does the work. All you need is something that can read ones and zeroes. A $50 DVD player will function just as well.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 13 Old 05-12-2012, 10:30 AM - Thread Starter
nbaptista's Avatar
If all the transports sound the same, why some are so expensive?or you mean like the dac has jitter rejection does not mind transport quality?
post #6 of 13 Old 05-13-2012, 09:29 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Because people who don't understand how audio works can be sold anything.
All DACs "reject" jitter. Some do it marginally better than others. But almost all do it so well that jitter is, or should be, of no concern.
Bottom line is, you have a very capable DAC, and it does not need anything special in a transport to sound its best.
mcnarus is offline
post #7 of 13 Old 05-14-2012, 08:20 AM - Thread Starter
nbaptista's Avatar
and a better power cord for the transport(Cambridge)? Is it irrelevant or no?
post #8 of 13 Old 05-14-2012, 08:36 AM
diomania's Avatar
Liked: 50
Click on "Search" tap at the top and type "power cord" in the "Keyword(s):" box and pick "Search Titles Only" just below that. Then pick "Audio Related" section in "Search in Forum(s)" at the lower right side. Then click on "Search Now". You'll get all the necessary info on it.
diomania is offline
post #9 of 13 Old 05-14-2012, 08:42 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Of course it's irrelevant.
mcnarus is offline
post #10 of 13 Old 02-15-2013, 12:11 PM
ThumbtackJack's Avatar
Quoted: 21 Post(s)
Good question. I suspect that one reason a transport can still make a difference if the data is completely reclocked is that digital noise associated with the low-to-high and high-to-low transitions (i.e., the risetimes and falltimes) of the signal that is received from the transport can to some degree couple past the buffer circuitry and contribute to jitter at the point where D/A conversion is performed. The coupling occurring via grounds, stray capacitances, and other possible paths through the circuitry.
The magnitude and character of that kind of effect figures to be dependent on unspecified and/or unspecifiable design characteristics of both components, and also the interconnect cable, and to not have a great deal of predictability.
ThumbtackJack is offline
post #11 of 13 Old 02-16-2013, 10:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Looks
Ergonomics
Reliability when used heavily (pro grade transports)
Degree of being radically overbuilt
If the DAC is competent...
arnyk is offline
post #12 of 13 Old 02-17-2013, 03:14 PM
runnin''s Avatar
Liked: 45
This is a bad suggestion. DVD players do not have the functionality of a cd player. Scanning through a track, repeating a track, random play, it's all much more complicated to operate on most DVD players. A 50 player probably won't last as long either due to bottom dollar parts, but that's another issue.
runnin' is offline
post #13 of 13 Old 02-18-2013, 10:55 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Often true, but if that's the kind of functionality you want, you're better off streaming than spinning disks.
My 9 y.o. Panasonic DVD player (orig. $80) seems to be working just fine. A $50 off-brand model might not stand up so well. But spending 10 times as much for even four times the lifespan would be a lousy deal.
mcnarus is offline
Reply CD Players & Dedicated Music Transports
