What turntable for 300 ish - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-17-2012, 02:39 PM - Thread Starter
shortyg83's Avatar
Quoted: 1050 Post(s)
Liked: 951
I have a chance to get a older rega planar 2 with a rb200 arm. It has no cartridge or needle. It is a older vintage one with glass platter and wood base. It is about 300. Is this a good deal? and if so what cartridge needle etc to get.
If there is a better buy please let me know.
shortyg83 is offline
post #2 of 17 Old 06-17-2012, 05:02 PM
CKWells's Avatar
I have a Planar 2 with the R200 arm. I use an AT95e cartridge.
It sounds good for the price. I paid about the same as you. If you can stretch a little you may have better luck with a new RP1, or maybe a Project Debut Carbon. Not sure what the going rate is for them where you are.
One good thing about the Rega though... You can get heaps of different upgrades for it, and most can be carried to a later/newer/better Rega down the line if you chose to move on. That's my current plan.
You can check out some crappy pics here... Rega Planar 2 (my HT pics thread).
Another popular cartridge option for a budget is the Ortofon 2M Orange.
CKWells is offline
post #3 of 17 Old 06-18-2012, 05:31 AM - Thread Starter
shortyg83's Avatar
Liked: 951
Well I wasn't able to get ahold of the rega planar 2 I wanted sadly.
So back to the drawing board.
Anyone have any other options in 300 range.
post #4 of 17 Old 06-18-2012, 08:51 AM
AndyPrice44's Avatar
I own a project debut 3 turntable. I feel that is the best turntable available in the 300 dollar price range. Try one with an ortofon 2m red cartridge. that should be within your budget and is a good entry level table.
AndyPrice44 is offline
post #5 of 17 Old 06-18-2012, 09:25 AM - Thread Starter
shortyg83's Avatar
Liked: 951
How do the project debut fair vs the rega planar 2 or 1
post #6 of 17 Old 06-18-2012, 09:39 AM
Paraneer's Avatar
Quoted: 55 Post(s)
Liked: 118
I am a Pro-ject guy having had a RM 1.3 and now an RM 5.1 SE. Never had a Rega so I cannot do a direct comparison. I can only say I like the Pro-jects very much, nver had any roblems with either table I've owned, and feel they are outstanding values for the money.
That being said, if you budget is $300 for a table & arm without a cartridge, then look at the new Pro-ject Carbon at $400 with a cartridge! It is a souped up version of their already best selling Debut III having the following upgrades - 8.6" full Carbon Fiber Arm, RCA jacks for your choice of cable, full 12" platter and factory equipped with the Ortofon 2M Red, a $100 cartridge that I believe was already recommended in this thread. In the $400 range for a table & a cartridge, Pro-ject appears to have a winner here. Hope this helps.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #7 of 17 Old 06-18-2012, 10:41 AM - Thread Starter
shortyg83's Avatar
Liked: 951
The project carbon does seem like a pretty good deal.
That ortofon red is a MM cartridge correct?
I am thinking of ordering a yaqin tube pre amp to match my amp. But it works better with a mm Cart
post #8 of 17 Old 06-18-2012, 03:49 PM
Paraneer's Avatar
Quoted: 55 Post(s)
Liked: 118
Yes, the Ortofon 2M Red is a MM cartridge. No worries. Good luck with your search amd may you enjoy whatever you purchase.
Paraneer is offline
post #9 of 17 Old 06-19-2012, 01:18 AM
CKWells's Avatar
Hahaha, in my post above I mention the 2M Orange as a budget cartridge. As all the other posts here suggest the Red is the budget option. The Orange certainly ain't!!!
Dunno what I was thinking.
On another note I had a look at the Debut Carbon the other day. Didn't have a listen, but it sure looks nice.
CKWells is offline
post #10 of 17 Old 06-19-2012, 05:35 AM - Thread Starter
shortyg83's Avatar
Liked: 951
I am probably ordering the Pro-ject Debut carbon today. Just waiting for needledoctor to open so I can give them a call.
post #11 of 17 Old 06-19-2012, 08:52 AM - Thread Starter
shortyg83's Avatar
Liked: 951
Ok so I ordered the Pro-ject Debut Carbon. And a Project phono box II pre amp.
I will let you all know how it sounds once it arrives.
post #12 of 17 Old 06-19-2012, 04:11 PM
CKWells's Avatar
Nice. Throw up some pics when you get it setup too!!
CKWells is offline
post #13 of 17 Old 06-20-2012, 04:10 AM
Class A's Avatar
Quoted: 434 Post(s)
Liked: 1733
Make sure your also getting some record cleaning supplies. A good record brush and some cleaning fluid.
Class A is offline
post #14 of 17 Old 06-20-2012, 05:38 AM - Thread Starter
shortyg83's Avatar
Liked: 951
I ordered a Pro-ject cleaning brush. But I don't know what fluid is good. Any recommendations?
post #15 of 17 Old 07-10-2012, 07:06 PM
Seth89's Avatar
Seth89 is offline
post #16 of 17 Old 03-05-2013, 01:09 PM
AnnapolisSony's Avatar
Quoted: 93 Post(s)
Liked: 138
So what is the verdict? How do you like it? I am considering this same turntable for my rack. Thanks in advance...
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is offline
post #17 of 17 Old 08-27-2013, 08:37 AM
jllphan's Avatar
I bought a Debut Carbon last week and love it. It struggles a bit with busy recordings, but acoustic music sounds amazing. There are a lot of haters claiming this is no audiophile table, but to my ears it's extremely satisfying.
HKtmartin likes this.
jllphan is offline
Reply CD Players & Dedicated Music Transports
