Best way to connect iPod Touch to old stereo (SONY STR-AV710) - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2012, 04:48 PM - Thread Starter
megabyzus's Avatar
Hi, I want to play the music on ITunes on my old 1989 receiver. It has typical RCA red and white audio RCA inputs. I have thought of at least one way to do this but I don't want to sway anyone's thinking with my solution yet to get ideas I haven't though of. I do have a limited budget and since this system is for the bedroom and old I don't plan to spend too much to get my iTunes to it. Any thoughts and ideas welcome and greatly appreciated.
megabyzus is offline
Old 06-19-2012, 09:57 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
Just use a 3.5 mm to RCA connector.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 06-20-2012, 09:22 AM - Thread Starter
megabyzus's Avatar
Thanks for the response. I was thinking something along the lines of a PyleHome PIPADK1 Handheld Device Cradle. It's a dock with a speaker out and it charges the IPod at the same time. From there I use the 3.5mm to RCA you mentioned.
Old 06-20-2012, 10:25 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3080
Of course. I gave you the simplest option but a dock should give you some additional features.
Old 07-10-2012, 07:53 PM
Seth89's Avatar
if you buy a dock get the apple dock. I see a lot of docks lose the charging feature after a year due to apple updates.
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=750551&Q=&is=REG&A=details
Seth89 is offline
Old 07-12-2012, 11:32 AM
Iheartmusic's Avatar
Try using an Apple Airport Express. You can use it to stream music from an apple wifi device to the Airport Express and play through the Receiver (which would be connected to the Airport device) You can also use an Apple TV Box to do the same thing if your tv audio is connected to the receiver.
Iheartmusic is offline
Old 07-16-2012, 09:27 PM
SID3W8Z's Avatar
... a better way, but costs a little bit of money...
Pure i-20 Dock
300
I'm not with the Crazies, They just like to stand next to me!
Headphone Audiophiles
SID3W8Z is offline
Old 07-16-2012, 10:28 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
On one of my systems I use something like this: http://amzn.com/B004SBBDD0
That method is similar to your dock plan, and it also let's you charge your iPod. By playing through the dock connector instead of the headphone jack, you should be bypassing the internal amplifiers. That's a good thing.
On a different ystem I'm using an airport express as mentioned above. The sound from it is really good as well, and being able to walk around and change songs with the device in my hand is a very nice convenience.
pitviper33 is offline
Old 07-17-2012, 04:45 AM
SID3W8Z's Avatar
I personally use the Airport Express with Optical Cable out to my receiver. What is nice is, that now that iTunes allows for higher bitrate files (I have a few 24bit/192khz) that I can pass along via the Airport Express to my system and let my receiver's DAC decode them. I can also not use my Mac (iTunes Server) or my NAS (also an iTunes server) and just put Pandora on my iPhone/iPad and send the output directly out to my Airport and play that on the receiver (you can do games and movies this way too).
Side note: With the dock I mentioned above, you can bypass the DAC in the iPhone/iPod/iPad completely and let the Dock do the work, or send the info out digitally and let your receiver's DAC do the work.
SID3W8Z is offline
Old 07-21-2012, 08:44 PM
psyopwak's Avatar
I agree with SID3W8Z on the PURE i-20. Nice device, great flexibility, and decent DAC. For a little more money, go with this.
http://www.logitech.com/en-us/speakers-audio/wireless-music-systems/squeezebox-touch
The best way to get to Itunes library with a great DAC built in, very adaptable and direct access to internet radio like MOG and PANDORA.
psyopwak is offline
Old 07-24-2012, 10:29 AM
Michael Hurley's Avatar
I don't suppose you recall what you paid for the STR AV-710? I have one that dies recently due to power line problems and I may be abble to file an insurance claim but I can't find the receipt (from 23 years ago!). Thanks.
MH
Michael Hurley is offline
