SACD Player that outputs DSD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2012, 07:11 PM - Thread Starter
nat120's Avatar
If I had a SACD player that can output DSD and it is hooked up via analog output to the input of an amplifier would I be getting the full quality of DSD? I know it makes a difference if it is hooked up via HDMI then the amplifier needs to be able to accept DSD.
nat120 is offline
post #2 of 3 Old 06-20-2012, 09:02 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Originally Posted by nat120 View Post
1.    If I had a SACD player that can output DSD and it is hooked up via analog output to the input of an amplifier would I be getting the full quality of DSD?
2.   I know it makes a difference if it is hooked up via HDMI then the amplifier needs to be able to accept DSD.
1.  If you are using the analog output, you are not getting DSD output.
2.  Not necessarily.  Just as the analog output can convey DSD after decoding to analog, HDMI can also output DSD as PCM.  This is more common than sending DSD.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 3 Old 06-21-2012, 03:30 AM
Kilian.ca's Avatar
Liked: 37
The short answer: yes
The long answer: it depends...
If the player's DAC is DSD capable (which can accept DSD signal) then a direct DSD to analogue conversion should normally retain the full quality of the DSD. This is in essence the reverse of a direct analogue-DSD recording in the simplest form.
Note many SACDs aren't original DSD recordings and you can't do bass management with direct DSD-analogue conversion. Even if you send DSD to the processor it often goes through PCM intermediate steps (and you rarely know what happens inside). And DSD recordings are edited via PCM (high sample rate) so very rarely you're getting a pure untouched DSD 'as is'.
If DSD is converted to PCM it needs decimation filter which might result in downsampling. Then PCM usually goes through an oversampling filter in the DAC. Whether you can hear any difference between DSD and PCM is debatable.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Reply CD Players & Dedicated Music Transports
