Technics sl-1700 compared to sl-1200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-02-2012, 08:15 AM - Thread Starter
curtiswhite's Avatar
I was in the market for a used tt. and i am thinking about getting a technics sl-1700 ( not a mk2) .How far off is the sl-1700 from a sl-1200 mk2.. I have heard they share allot of the same parts. So as far as sq goes are they similar or is there a big difference ?
This being, that becomes;
On the arising of this, that arises.
This not being, that does not become;
On the cessation of this, that ceases.
curtiswhite is offline
post #2 of 3 Old 07-10-2012, 06:50 PM
Seth89's Avatar
how are you getting the 1700, on ebay?
if you want something new out of the box AudioTechnica makes a replica of that unit.
see here http://www.amazon.com/Audio-Technica-AT-PL120-Professional-Direct-Drive-Turntable/dp/B00012EYNG
or if you want to dump the old silver decor you can get this one
http://www.audio-technica.com/cms/turntables/1dd57155b119cdad/
I have the 2nd unit listed (lp-240) and its the real deal. best part is that it is under 1,000. runs for around 400 and can be found for 300ish online. unit doesn't come with a cartridge.
Seth89 is offline
post #3 of 3 Old 01-29-2013, 08:24 PM
drceea's Avatar
Hi, I realize this response comes a bit after your last post and how do you know the AudioTechnica is a replica? Forgive my ignorance in this question, I do not mean to condescend.
Thank you,
CA
drceea is offline
Reply CD Players & Dedicated Music Transports
