is it worth getting into sacd ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-02-2012, 01:11 PM - Thread Starter
curtiswhite's Avatar
So at the local good will store they have a 5 disc sony sacd player for only $ 24 . I looked up the model and it got real good reviews. So at this point is it really worth going down the sacd road if not into classical music.?
This being, that becomes;
On the arising of this, that arises.
This not being, that does not become;
On the cessation of this, that ceases.
curtiswhite is offline
post #2 of 15 Old 07-02-2012, 01:30 PM
glangford's Avatar
Quoted: 198 Post(s)
Liked: 170
If you are not into classical or jazz, then maybe not. Most issues are in those two categories. I'm also of the mindset that high rez music for clipping guitar amps and overdriven mics is almost a waste. That said, there are some very good releases like Pink Floyd, but they are far and few between.
glangford is offline
post #3 of 15 Old 07-02-2012, 01:33 PM
wlcohen's Avatar
Yes, I bought the OPPO a few years ago and since it played SACD's I went out and got a few
They do sound much better.
wlcohen is offline
post #4 of 15 Old 07-02-2012, 03:46 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
No, it is not worth "getting into" any format. You should buy the music you want to hear, and not think twice about which format it's on. In those (relatively rare) cases where you do have a choice of format, then, yeah, try the non-CD version if the price premium isn't too dear. But always remember, it's the music not the medium.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 15 Old 07-02-2012, 10:00 PM
tesseract67's Avatar
$24 isn't that much to satisfy your curiosity. I say go for it, there is plenty of SACD music out there and the Sony still plays Redbook CD's, too.
"Women and cats will do as they please, and men and dogs should relax and get used to the idea." -Robert A. Heinlein
tesseract67 is offline
post #6 of 15 Old 07-03-2012, 01:08 AM
Kilian.ca's Avatar
Liked: 37
If the changer only has 5.1 analogue out and your AVR doesn't have MCH in then it's not really worth it. I doubt you'll generally notice much improvement in 2ch SACD. If it's a remaster it should be available on CD. I suppose if you're that interested in high rez or a classical/jazz fan you'd have got into it ages ago.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #7 of 15 Old 07-03-2012, 07:42 AM
Rutgar's Avatar
So... We should have all just stuck with 8-track tapes?
Rutgar is offline
post #8 of 15 Old 07-03-2012, 11:02 AM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
I'm guessing the changer could be the SCD-CE595 and if so, you bring up a good point.
*Multichannel analog audio outputs facilitate hookup with compatible audio/video receivers and multichannel amplifiers
*Optical digital-audio output (CD only) permits simple connections with CD and minidisc recorders
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #9 of 15 Old 07-03-2012, 04:08 PM - Thread Starter
yep that's it scd-ce595... I'm gonna pick it up in a day ,if its still there. Maybe there be some sacds in the stack . I have a onkyo tx-sr805 that has the analog 5.1 inputs.
post #10 of 15 Old 07-03-2012, 07:04 PM
If the Sony is gone, or even if it isn't, consider finding a used universal player. This allows you to check out DVD-A, too. A lot of HiRez is recorded in that format.
Myself, I wouldn't want to be limited to SACD only.
post #11 of 15 Old 07-04-2012, 08:38 AM
joegut's Avatar
The SCD-CE595 is a fine player. Go for it. It will make your regular CDs sound better, I kid you not. The Stones SACDs sound great, Dark Side Of The Moon, sounds really good, Leo Kottke's first album sounds good, Layla sounds REALLY good. $24? Man, I'd be camping out at that Goodwill store waiting for that player!
joegut is offline
post #12 of 15 Old 07-04-2012, 05:01 PM - Thread Starter
Yea the goodwill was closed today 4th. So first thing after work I'm gonna get it. Hopefully its still there. I should have picked it up the first time . This would be my first good find at a goodwill . Now if I can just score a good tt.
post #13 of 15 Old 07-05-2012, 04:37 PM - Thread Starter
Well I got it . I'm playing regular CDs for now. One question is there any sq difference for regular cd using fiber or RCA.?
post #14 of 15 Old 07-05-2012, 07:12 PM
Kilian.ca's Avatar
Liked: 37
Depends who you ask. An innocent query can turn into flame war here. Some vehemently believe all CD players sound the same, all cables sound the same, all DACs sound the same, all amps sound the same etc. Others not so.
Try it both ways for yourself. For SACD you'll have to use analogue (RCA).
post #15 of 15 Old 07-05-2012, 07:14 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
It isn't a flame war until some jerk decides to make it a flame war.
mcnarus is offline
Reply CD Players & Dedicated Music Transports
