Playing Music CD on Crosley Director - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-15-2012, 01:08 PM - Thread Starter
Lindon's Avatar
Just when I think I have mastered making CD's, I encounter another challenge. My Crosley Director will play back a CD on which I have copied a commercial music CD album. However it will not play back a CD on which I have copied individual MP3 songs. A message appears on the screen: NO TOC CD-RW as if the CD was not finalized, but it was finalized. Any thoughts on what's going on here?
Lindon is offline
post #2 of 4 Old 07-15-2012, 01:32 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
My guess is it's a matter of formats. Your Crosley can play uncompressed formats, such as that used for standard CDs, but not compressed formats like MP3. You'll need to convert your MP3 files to an uncompressed format (WAV or AIFF) before copying them to CD. This will make those files much larger, of course, but will not alter the sound, either for better or worse.
By any chance are you using iTunes to burn your CDs?
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 4 Old 07-15-2012, 02:31 PM - Thread Starter
Lindon's Avatar
Thanks for your suggestions. I'm using Express Burn. I'll post the results.
Lindon is offline
post #4 of 4 Old 07-15-2012, 06:03 PM - Thread Starter
Lindon's Avatar
Converting the mp3 files to wav resolved the problem. THANK YOU VERY MUCH!! I may need more help when I try to copy LP records and cassette tapes to CD's with the Crosley Director.smile.gif
Lindon is offline
Reply CD Players & Dedicated Music Transports
