Sacd player - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2012, 12:06 PM - Thread Starter
Pat Conway's Avatar
Hello, Looking for a sacd player. I'm looking to spend around 200 dollars. I will hook it up to a pioneer Sc 55 reciever. Hdmi will be used. Any suggestions will be greatly appreciated. Thank you!!
Pat Conway is offline
Old 08-26-2012, 05:00 PM
bradman's Avatar
Quoted: 17 Post(s)
Liked: 24
Get a Sony Blu-Ray player. They output DSD over HDMI and are well within your price range.
bradman is offline
Old 08-26-2012, 10:44 PM - Thread Starter
Pat Conway's Avatar
Thanks. Would the difference between a oppo 93 and the Sony to justify the extra cost. I have a blue ray player already. Thanks
Old 08-27-2012, 01:50 AM
Kilian.ca's Avatar
Liked: 37
For SACDs, nothing extra to justify the extra cost. Sony sends out higher resolution PCM.
Sony can send out DSD, or PCM at 176.4kHz from SACDs via HDMI.
Oppo can send out DSD, or PCM at 88.2kHz from SACDs via HDMI.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Old 08-27-2012, 02:13 PM
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Which Sony player can send out DSD or PCM at 176.4 kHz from SACD vian HDMI?
gbaby is offline
Old 08-30-2012, 07:57 PM
moxie1617's Avatar
At least all models for the past two years. They support DSD over HDMI and if you need PCM, it will send it out at 176.4 kHz sample rate (176.4/24).
moxie1617 is offline
Old 08-30-2012, 09:11 PM
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
I own the S780 and when I tried to connect it to my processor for SACD over HDMI I got a distorted signal. Its probably a configuration issue.
gbaby is offline
Old 08-31-2012, 05:58 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Another consideration would be an ability to play a copy of SACD on DVD-R media. It is more important going forward, as there is less and less opportunity to find SACD disks new. But copies of old records are commonly available. None of the SONY players can play SACD on DVD-R. Oppo BD player work, older OPPO DVD players require customized firmware. Most Pioneer DVD players work too. There are several web sites dedicated to SACD copying (they refer to them as SACD-R), you can find more information there.
ap1 is offline
