Best and cheapest SACD Player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-01-2012, 07:15 AM - Thread Starter
Tweaked05's Avatar
Quoted: 49 Post(s)
Liked: 34
I have been thinking about buying an SACD player and noticed that nearly all Sony BD players also play SACD. Are these good? Is there a really good SACD player that is also cheap?
Tweaked05 is offline
post #2 of 13 Old 09-01-2012, 09:30 AM
twitch54's Avatar
for the money...Oppo
twitch54 is offline
post #3 of 13 Old 09-01-2012, 09:42 AM - Thread Starter
Tweaked05's Avatar
Quoted: 49 Post(s)
Liked: 34
Perhaps I should have specified what I meant by cheap. I am looking to spend no more than $150.
post #4 of 13 Old 09-01-2012, 11:25 AM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #5 of 13 Old 09-01-2012, 12:33 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Well, can you buy a Sony BP for $150? If so, your problems are solved!
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #6 of 13 Old 09-02-2012, 06:18 AM
JD NC's Avatar
Liked: 40
If your AVR is able to decode DSD sent over hdmi, any hdmi capable sacd player should do. Check the manual.
Most Sony DVD and BD players support sacd, even the super cheap ones. Also check out the Pioneer DV-610AV. It's $100-120, plays sacd and DVD-audio, and has controls on the front panel so it's possible to navigate without the remote if you just want to play music without messing with the remote or tv screen. Downside is that doesn't play blu ray, but if you can spare the extra hdmi port, you can get the Pio and a good BD player for significantly less than the cost of the Oppo. Dont get me wrong, the Oppo is awesome, but $500 is a steep cost of entry, considering how good bluray and DVD playback is from a much less expensive Sony or panasonic bd player.
JD NC is offline
post #7 of 13 Old 09-04-2012, 03:20 AM
glangford's Avatar
Quoted: 316 Post(s)
Liked: 255
Your avr does not need to decode DSD. A sony can send 176 khz pcm to the reciever.
glangford is offline
post #8 of 13 Old 09-12-2012, 03:39 PM
oldtexasdog's Avatar
Try to find"It can be done!" a Oppo BD83- you will love it and not need to buy another player for a long time!
There are two holes in Daddys head where all the money goes.
oldtexasdog is offline
post #9 of 13 Old 09-15-2012, 06:07 AM
moxie1617's Avatar
If your receiver can handle DSD or PCM over HDMI, then the Sony is fine for SACD. If your receiver can only support analog then get an Oppo.
moxie1617 is offline
post #10 of 13 Old 09-19-2012, 08:52 PM
Christian's Avatar
I would also recommend Oppo, but in your price range, search eBay and look for used Denon/Sony universals.
A used Denon DVD-2900 was pretty durn good on SACD (I sold mine a ways ago), and probably be sub-$200. Also had a Sony DVP-NS900V - decent as well too, with SACD.
If you can stretch it, a used Sony ES SACD (or DVD) player would fit the ticket, but you're getting awfully close to a new Oppo.
Christian is offline
post #11 of 13 Old 09-20-2012, 02:12 PM
pdjmwj's Avatar
Quoted: 33 Post(s)
Onkyo DV-SP1000, built like a tank. An excellent SACD player. I own it along with an OPPO BDP-95.
The OPPO is better but not by much.
This Onkyo is well built and spec'd out is you can find one.
Lifes a beach and then you die....
pdjmwj is offline
post #12 of 13 Old 10-03-2012, 06:24 PM
curtiswhite's Avatar
If you can find a used one look for a sony scd-ce595 Its not hdmi but its analog 5.1. I found one for $20 at gw. I see a couple on ebay for around $75.00. Also check on CL. GL !
This being, that becomes;
On the arising of this, that arises.
This not being, that does not become;
On the cessation of this, that ceases.
curtiswhite is offline
post #13 of 13 Old 10-09-2012, 08:13 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
I have sent you a PM!
Glenn Baumann is offline
Reply CD Players & Dedicated Music Transports
