Looking for a record player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-13-2012, 11:38 PM - Thread Starter
fordfreak's Avatar
I have a family member that has a good sized record collection. They haven't been used in quite a while. I'd like to get a record player for my HT system so I can play them. I'd also like to be able to hook it up to my PC so I can turn the tracks into FLAC files. I don't think that should be a problem using the audio input jack. My PC sound card is an Auzentech Prelude.
Having said that, what player would you recommend?
fordfreak is offline
post #2 of 5 Old 10-14-2012, 07:35 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
But, seriously, how much do you want to spend?
Also, does your AVR have a phono input? If not, you'll need a phono preamp. (And you might want a separate one anyway for hooking up to the PC.) We'll have to figure that into the budget.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 5 Old 10-14-2012, 02:00 PM
kraut's Avatar
Liked: 61
From my experience I'd say look for a good used dual, thorens or technics. I bought several on eBay. Buy from a reliable seller only.
Consider also you might have to pay for a new cartridge. I found the Denon dl 160 to be quite accurate with fairly flat FR. This needs only a phonopreamp for MM (moving Magnet) cartridge.
And yes, you need a phono preamp. They are available from behringer http://www.amazon.ca/Behringer-PP400-Ultra-Compact-Phono-Preamp/dp/B000H2BC4E , art http://www.musiciansfriend.com/pro-audio/art-djpre-ii-phono-preamp.
kraut is offline
post #4 of 5 Old 10-14-2012, 10:02 PM - Thread Starter
fordfreak's Avatar
Those are way out of my price range. I didn't think record players got that expensive. I'm thinking $500 max for the player itself. Maybe up to $1,000. My AVR is a Denon AVR-3808CI. There is a phono input listed on it.
post #5 of 5 Old 10-15-2012, 02:08 AM
kraut's Avatar
Liked: 61
kraut is offline
Reply CD Players & Dedicated Music Transports
