CD Player with wireless speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-25-2012, 07:42 AM - Thread Starter
Lazydaze's Avatar
My wife and I listen to audio books on CD's. We would like to place speakers in different parts of house while listening; this way we don't have be in one area. I've looked all over the web with no results.
Anyone have any Idea.
I've even thought about using my laptop I have a mac-pro and an older PC, but that would be a wi-fi situation and I'm not familiar with the technology.
Neil
Lazydaze is offline
post #2 of 7 Old 10-25-2012, 02:04 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
WiFi would seem to be the way to go. Load your audio books into iTunes. Buy an Airport Express and a pair of powered speakers for each room where you want to play. iTunes allows you to designate any or all of your AEs to receive the WiFi stream.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 7 Old 10-25-2012, 05:15 PM - Thread Starter
Lazydaze's Avatar
I don't have the new airport express small unit, but I do have a larger looking AE unit which is a router and a hard drive and uses airport utility. Can this be used with wifi speakers.
Also instead of loading audio books into Itunes, wouldn't it work if I just put the cd's into the mac onboard cd/dvd player?
Lazydaze is offline
post #4 of 7 Old 10-25-2012, 05:32 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
I don't know what you're talking about. So far as I remember, Airport Express never came with a hard drive. Is this an old Apple TV unit, perhaps? Or Time Machine? I think you could hook up speakers to the former, but not the latter.
Yes, that should work.
mcnarus is offline
post #5 of 7 Old 10-25-2012, 05:45 PM - Thread Starter
Lazydaze's Avatar
The unit is a time machine.
Lazydaze is offline
post #6 of 7 Old 10-25-2012, 06:25 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Not what you need. AE is the right tool for the job.
mcnarus is offline
post #7 of 7 Old 10-25-2012, 07:15 PM - Thread Starter
Lazydaze's Avatar
Thanks for all the help.
Lazydaze is offline
Reply CD Players & Dedicated Music Transports
