Why the scratching and popping noise? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-15-2012, 03:19 PM - Thread Starter
357mag's Avatar
Quoted: 36 Post(s)
I have got a noise coming out of my speakers when I play a CD. I thought at first it was the speakers but I've ruled those out. I ordered a CD Lens Cleaner and I'll try that when it comes. Unless some speaker cables are somewhat loose, I'll have to check those too. I've got a refurbished Denon CD Changer.
357mag is offline
post #2 of 3 Old 11-16-2012, 05:36 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Unlike with turntables, when you hear strange noises from CD player, it means that electronics in it is broken. Laser problem usually manifests in skipping or inability to play at all. So I suspect you need an new player now.
ap1 is offline
post #3 of 3 Old 11-16-2012, 09:36 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Is the noise in one channel or both?
If you haven't already, try unplugging and reconnecting everything. Also try connecting the CD player to a different input.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Reply CD Players & Dedicated Music Transports
