CD player for $400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 12-08-2012, 07:33 PM - Thread Starter
bcarroll01's Avatar
I have been slowly piecing together what I would like for my stereo system. I am now looking for a good CD player with a budget of $400 and possibly could do $450. I have looked at some from emotiva and marantz and yamaha but I am not sure what to look for to make sure I am getting the best one for the money. Also what is the best way to connect it to my Yamaha A710?
bcarroll01 is offline
post #2 of 47 Old 12-08-2012, 09:33 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3724
The Marantz CD5004 is a decent buy at $350. They have a demo at audioadvisor.com for $300. They have even cheaper prices at accessories4less for refurbished units. Of course, you could just burn your CDs and use a music server and your computer. wink.gif
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is online now
post #3 of 47 Old 12-09-2012, 09:05 AM - Thread Starter
bcarroll01's Avatar
I have thought about just streaming but I also have a lot of CD's I don't have on my computer that it would be nice to play without having to spend the time and HD space burning them.
post #4 of 47 Old 12-09-2012, 10:03 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The best way to connect a music player to an AVR is digitally. A digital connection makes the converters, etc. in the music player irrelevant, so players in the $100 price are applicable.
The alternatives add complexity and cost with no sound quality advantage.
arnyk is offline
post #5 of 47 Old 12-09-2012, 10:17 AM - Thread Starter
bcarroll01's Avatar
So at that point looking at the emotiva cd player that has balanced outputs wouldn't matter if I use digital?
post #6 of 47 Old 12-09-2012, 11:00 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
So at that point, it wouldn't be any better than a $70 DVD player, because the DACs in the AVR are doing all the work.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #7 of 47 Old 12-09-2012, 11:34 AM - Thread Starter
bcarroll01's Avatar
If I wanted to not go digital and possible add a DAC in the future what should I look for in a CD player?
post #8 of 47 Old 12-09-2012, 01:43 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Why do you want to do that?
Why might you want to do that?
Neither will make your system sound better. The first might actually preclude some real improvement to sound quality. It's hard to advise you about how to go about doing something that doesn't make much sense.
mcnarus is offline
post #9 of 47 Old 12-09-2012, 02:32 PM
pbarach's Avatar
Quoted: 373 Post(s)
Liked: 221
I have this Marantz player, and it does a fine job using the analog outs. I'm using it that way with a headphone amp. As someone else noted, if you connect it to a receiver digitally, you will be using the DACs in the receiver instead of the ones in the player. Hard to say which will sound better--you'd have to compare them in your system.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #10 of 47 Old 12-09-2012, 09:38 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I'm very happy with a Harmon/Kardon HCD 990. I got it for around $400 on a deal.
If you use digital outs, all working transports will sound identical.
lespurgeon is offline
post #11 of 47 Old 12-10-2012, 10:12 AM - Thread Starter
bcarroll01's Avatar
I meant to put if I want to go digital.
post #12 of 47 Old 12-10-2012, 10:36 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Yes. Balanced outputs relate only to analog.
There is no real world balanced output that has the low noise and distortion that we take for granted with digital.
arnyk is offline
post #13 of 47 Old 12-11-2012, 08:31 AM
runnin''s Avatar
Liked: 45
The Yamaha A710 is a mid range AVR. So it's not going to do as good a job at converting digital to analog as a good CD player would. On the other hand, I doubt it has a good enough pre amp or analog section to allow a component upstream to really sparkle. You might as well get a CD player with the idea of passing digital to the AVR.
runnin' is offline
post #14 of 47 Old 12-11-2012, 08:43 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Somebody else who thinks price is a technical spec.
Sure it will.
Source components are not supposed to "sparkle." They are supposed to deliver a clean signal to the receiver. And if you put a clean signal into a "mid range AVR," you will get a clean signal out.
mcnarus is offline
post #15 of 47 Old 12-11-2012, 08:55 AM
runnin''s Avatar
Liked: 45
The phrase, "mid range AVR" is really not controversial, and I was not referring to cost. Everything else in your post is not worth bothering with a response.
To the OP, I would suggest taking all opinion with a grain of salt, too many people about here these days with some kind of axe to grind. Take your time, read up on things, and don't let people brow beat you(as some already have tried) into making a decision that they approve of.
runnin' is offline
post #16 of 47 Old 12-11-2012, 09:02 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
It should be. It's just audiophile bull
Funny!
mcnarus is offline
post #17 of 47 Old 12-11-2012, 09:05 AM
diomania's Avatar
Liked: 50
Have you tried it yourself?
diomania is offline
post #18 of 47 Old 12-11-2012, 10:19 AM
JA Fant's Avatar
Quoted: 347 Post(s)
Liked: 562
A nicely musical cd player either the Creek or Music Hall gear. Happy Listening!
JA Fant is offline
post #19 of 47 Old 12-11-2012, 11:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Speculation, or do you have reliable evidence to back that up?
Can you quantify this "sparkle" thing?
arnyk is offline
post #20 of 47 Old 12-11-2012, 11:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Can you quantify "a nicely musical"?
arnyk is offline
post #21 of 47 Old 12-11-2012, 12:36 PM
runnin''s Avatar
Liked: 45
Please provide scientific evidence that proves your position, or it's just enthusiast guessing.
runnin' is offline
post #22 of 47 Old 12-11-2012, 12:42 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Sorry guy, but you are the guy making claims. So, it is up to you to give your claims hands and feet or just let them die.
If there is an enthusiast guessing here, its not me because I'm an EE with over 40 years of experience, dozens and dozens of DBTs, test equipment in my back bedroom, the whole 9 yards.
arnyk is offline
post #23 of 47 Old 12-11-2012, 12:54 PM
runnin''s Avatar
Liked: 45
Trotting out your subjective experience is not evidence.
I assume you have no scientific evidence then?
runnin' is offline
post #24 of 47 Old 12-11-2012, 01:54 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
DBTs are scientific evidence. I also measured test equipment bench tests which are also scientific.
What do you have beyond that highly scientific sounding "sparkle" thing? ;-)
arnyk is offline
post #25 of 47 Old 12-11-2012, 02:05 PM
runnin''s Avatar
Liked: 45
Since you obviously don't have any DBT on the matter at hand, that is AVR vs a good cd player performance, then I won't hold my breath that you can back up your subjective opinions with anything more than guesses.
runnin' is offline
post #26 of 47 Old 12-11-2012, 02:26 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
You're the guy making the exceptional claim that despite the excellent technical performance of the AVR, there's something sonically missing.
If there is something missing, where its measured absence, what is it and where did it go?
arnyk is offline
post #27 of 47 Old 12-11-2012, 06:08 PM - Thread Starter
bcarroll01's Avatar
Just to see if I am understanding everything right so far. If I plan on using digital connectors and letting the avr doing the converting I should Just stick with a CD player that will play all of the CD formats I need. If not then the CD player becomes more important.
post #28 of 47 Old 12-12-2012, 03:15 AM
glangford's Avatar
Quoted: 317 Post(s)
Liked: 255
You never mentioned formats? CDs have one format. Do you want a SACD player, DVD-A player, something to decode HDCD? None of this has been part of the conversation. A 70 dollar dvd player with optical or coax output will play CDs. If you want the other formats I've mentioned then start looking at universal players from Denon, Marantz, Pioneer, Yamaha, or Oppo. The cheapest starts around 399.
glangford is offline
post #29 of 47 Old 12-12-2012, 06:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Yes.
arnyk is offline
post #30 of 47 Old 12-12-2012, 08:56 AM - Thread Starter
bcarroll01's Avatar
What I meant was purchased cds and also burned ones.
Reply CD Players & Dedicated Music Transports
