Turntable help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-15-2012, 11:30 PM - Thread Starter
kbeam418's Avatar
Location: 41.7080574, -83.5911255 N41° 42.4834', W083° 35.4675'
Liked: 47
If this is in the wrong part of the forums go ahead and move it. So I have an old Jcpenny turntable I hooked it up to my Aiwa stereo receiver turned up the gain but something just doesn't sound right.
The turntable is outputing through the aux jacks there are no groundloops and no feedback but towards the end of my Dark Side of the Moon LP (great album) the sound quality is horrible it's like the turntable is being overloaded, and it sound like a bad mp3. The album is Pink Floyd's Dark Side of the Moon remastered and is brand new, the only thing that's "wrong" with it is that it attracts lint. Thanks for the help everyone.
"Then one day you find ten years have got behind you no one told when to run you missed the starting gun."
kbeam418 is offline
post #2 of 5 Old 12-15-2012, 11:44 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 317
Class A is offline
post #3 of 5 Old 12-16-2012, 01:04 AM - Thread Starter
kbeam418's Avatar
Liked: 47
Originally Posted by Class A View Post
I'm not sure entirely sure, the tt mostly likely doesn't because it is quite old and the receiver I got from my Aunt. The receiver has a input level control for the phone jacks if that means anything. It's a Aiwa NSX-999 it's from 1995.
kbeam418 is offline
post #4 of 5 Old 12-16-2012, 08:20 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
First of all, the symptoms you are describing do not sound like you're missing a phono preamp. But just to be sure, there should be an set in inputs on your receiver labeled "phono." Make sure your turntable is plugged into those.
Distortion at the end of a record size is inevitable, but if the problem is extreme it suggests that the cartridge is misaligned.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 5 Old 12-16-2012, 11:58 AM - Thread Starter
kbeam418's Avatar
Liked: 47
There is no phono input. I'm going to buy a pre-amp and will also get a new cartridge.
kbeam418 is offline
Reply CD Players & Dedicated Music Transports
