Are all 2 volt out digital sources as loud as Rotel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-18-2012, 09:51 PM - Thread Starter
kashmereino's Avatar
I just changed digital sources in my system, and I originally was using a Rotel CD, and hooked up a Sony DVP-S999ES DVD/CD player to listen to the same CD. I immediately noticed a huge change in volume, the Rotel is much louder. Why should there be so much of a difference in output from one CD player to another? I believe both components are standard 2 volts out.
kashmereino is offline
post #2 of 2 Old 12-19-2012, 06:09 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
According to
http://esupport.sony.com/US/p/select-system.pl?DIRECTOR=DOCS
There appears to be no such thing as a DVPS999ES.
And of course you didn't say squat about the Rotel.
At any rate rather than wasting our time doing your homework why don't you do your own research, compare the spec sheets and report back?
arnyk is offline
Reply CD Players & Dedicated Music Transports
