Harman Kardon Scratch/Hiss Sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-03-2013, 02:34 AM - Thread Starter
Happs's Avatar
I have a Harman Kardon FL8550 5 CD changer that plays about 40% of my CD's fine and the other 60%, plays them with a pronounced hiss or scratchy sound in the background. There is no rhyme or reason which discs play fine and which discs play with a hiss or scratch. Older, newer, classical, rock, makes no difference on outcome. I have tried cleaning the lens with a dry cd lens cleaning disc that has brushes on it and there is no difference. Any ideas on what's going on?
Happs is offline
post #2 of 2 Old 01-07-2013, 11:40 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
Chances are that the loading mechanism is loading them off-center and having a hard time tracking the disc.
If it is old, I would replace it. If it's under warranty, send it in for repair.
commsysman is offline
Reply CD Players & Dedicated Music Transports
