Marantz cd5004 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-17-2013, 04:48 PM - Thread Starter
waynow's Avatar
Marantz cd5004.
Which connection should I use, Analog or Digital. The unit has a "Audio EX Function" EX - off which is digital. EX1 digital. And the one Im confused about is the EX 2 which is analog but states that it plays audio at the highest quality sound. I always thought digital is the way to go to produce the bes possibe sounds. Denon the AVR its connecting with claims an Anolog connection will degrads the sound. Any idea on the matter is sure aprecitave.
waynow is offline
post #2 of 2 Old 01-17-2013, 05:58 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Use the digital connection. In terms of basic sound quality, it doesn't matter. But your Denon probably re-digitizes it anyway, so you might as well send it the digital signal to statr with.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Reply CD Players & Dedicated Music Transports
